1998-11-19 | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 2 | -11/+12 | |
1998-11-19 | Changed version string. | Joel Sherrill | 2 | -2/+2 | |
Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | |||||
1998-11-19 | Applied updates from remote work while doing class. | Joel Sherrill | 1 | -1/+1 | |
1998-10-27 | Clarifed description of driver name. | Joel Sherrill | 1 | -1/+4 | |
1998-10-12 | Added some fields and changed last KA9Q reference to FreeBSD. | Joel Sherrill | 1 | -1/+12 | |
1998-09-10 | Fixed back so it would build. | Joel Sherrill | 1 | -0/+2 | |
1998-09-10 | Added references. | Joel Sherrill | 1 | -0/+33 | |
1998-09-08 | Removed chapter names from automatically generated node names. | Joel Sherrill | 2 | -3/+5 | |
1998-09-08 | Fixed include file path. | Joel Sherrill | 1 | -1/+1 | |
1998-08-21 | Patch from Eric Norum | Joel Sherrill | 1 | -10/+9 | |
1998-08-21 | Update from Eric Norum. | Joel Sherrill | 1 | -4/+23 | |
1998-08-19 | First version produced. | Joel Sherrill | 3 | -2/+3 | |
1998-08-19 | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 5 | -21/+21 | |
1998-08-19 | Baseline | Joel Sherrill | 9 | -0/+2321 | |
