* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -1/+1 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Added instructions on running ttcp from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 2000-03-24 | 1 | -0/+37 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added information on debug modes that can be enabled in the network stack. | Joel Sherrill | 1999-02-09 | 1 | -0/+45 |
* | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1998-11-19 | 1 | -3/+3 |
* | Baseline | Joel Sherrill | 1998-08-19 | 1 | -0/+175 |
