path: root/doc/networking/stamp-vti (unfollow)
2017-01-11Remove texinfo format documentation. Replaced by Sphinx formatted documentation.Joel Sherrill1-4/+0
closes #2812.
2013-02-26doc: Update version.texi and stamp-vti filesJoel Sherrill1-2/+2
See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html for instructions on how to do this.
2010-06-11New.Ralf Corsepius1-0/+4
2003-01-222003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-4/+0
* version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort.
2003-01-212003-01-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+2
2002-11-132002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+2
2002-10-242002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+2
2002-07-302002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+2
2002-01-20regeneratedJoel Sherrill1-2/+3
2002-01-20regeneratedJoel Sherrill1-2/+2
2002-01-172001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+2
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation.
2000-06-01Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1-0/+3
Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
