2017-01-11 | Remove texinfo format documentation. Replaced by Sphinx formatted documentation. | Joel Sherrill | 1 | -924/+0 | |
closes #2812. | |||||
2015-02-11 | doc: Document network task affinity option | Daniel Cederman | 1 | -0/+14 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2010-02-18 | 2010-02-18 Chris Johns <chrisj@rtems.org> | Chris Johns | 1 | -7/+25 | |
* networking/networkapp.t: Updated the BOOTP/DHCP to document the default behaviour of looping forever. | |||||
2008-09-09 | Convert to "bool". | Ralf Corsepius | 1 | -2/+2 | |
2008-02-05 | 2008-02-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -5/+62 | |
* networking/networkapp.t: Add configuration parameters for network stack efficiency multiplier and default socket buffer sizes. | |||||
2003-10-02 | 2003-10-02 Gene Smith <gene.smith@siemens.com> | Joel Sherrill | 1 | -3/+41 | |
* networkapp.t, preface.texi: Improve documentation for SO_RCVWAKEUP and SO_SNDWAKEUP and update the references in the preface. | |||||
2003-02-11 | 2003-02-11 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 1 | -1/+320 | |
* networkapp.t: Add an example code snippet for adding a default route. | |||||
2003-02-11 | 2003-02-11 Mike Siers <mikes@poliac.com> | Joel Sherrill | 1 | -0/+34 | |
* networkapp.t: Add an example code snippet for adding an IP alias. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
2000-05-25 | Minor corrections from Nick Simon <Nick.SIMON@syntegra.bt.co.uk>. | Joel Sherrill | 1 | -2/+2 | |
- char * nameserver[3] appears twice, second occurrence should be ntpserver - in sect 3.3.3 ...ifcontig should be ifconfig | |||||
2000-01-21 | Documentation to reflect patch from Eric Norum <eric@cls.usask.ca> to | Joel Sherrill | 1 | -2/+11 | |
the network initialization enhancement request by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-11-11 | Added information about the NTP servier field and included a copy | Joel Sherrill | 1 | -2/+68 | |
of the C definition of the configuration structure. | |||||
1999-10-25 | Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were | Joel Sherrill | 1 | -11/+10 | |
backwards. | |||||
1999-07-03 | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1 | -3/+67 | |
getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | |||||
1998-12-17 | Updated socket information | Joel Sherrill | 1 | -1/+2 | |
1998-12-10 | Document from Ian Lance Taylor <ian@airs.com> on the tap function. | Joel Sherrill | 1 | -0/+28 | |
1998-11-19 | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1 | -8/+9 | |
1998-10-12 | Added some fields and changed last KA9Q reference to FreeBSD. | Joel Sherrill | 1 | -1/+12 | |
1998-09-08 | Fixed include file path. | Joel Sherrill | 1 | -1/+1 | |
1998-08-21 | Patch from Eric Norum | Joel Sherrill | 1 | -10/+9 | |
1998-08-21 | Update from Eric Norum. | Joel Sherrill | 1 | -4/+23 | |
1998-08-19 | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 1 | -3/+3 | |
1998-08-19 | Baseline | Joel Sherrill | 1 | -0/+250 | |
