* | 2010-02-18 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-02-18 | 1 | -7/+25 |
| | | | | | * networking/networkapp.t: Updated the BOOTP/DHCP to document the default behaviour of looping forever. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-09 | 1 | -2/+2 |
* | 2008-02-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-02-05 | 1 | -5/+62 |
| | | | | | * networking/networkapp.t: Add configuration parameters for network stack efficiency multiplier and default socket buffer sizes. | ||||
* | 2003-10-02 Gene Smith <gene.smith@siemens.com> | Joel Sherrill | 2003-10-02 | 1 | -3/+41 |
| | | | | | * networkapp.t, preface.texi: Improve documentation for SO_RCVWAKEUP and SO_SNDWAKEUP and update the references in the preface. | ||||
* | 2003-02-11 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2003-02-11 | 1 | -1/+320 |
| | | | | * networkapp.t: Add an example code snippet for adding a default route. | ||||
* | 2003-02-11 Mike Siers <mikes@poliac.com> | Joel Sherrill | 2003-02-11 | 1 | -0/+34 |
| | | | | * networkapp.t: Add an example code snippet for adding an IP alias. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Minor corrections from Nick Simon <Nick.SIMON@syntegra.bt.co.uk>. | Joel Sherrill | 2000-05-25 | 1 | -2/+2 |
| | | | | | | - char * nameserver[3] appears twice, second occurrence should be ntpserver - in sect 3.3.3 ...ifcontig should be ifconfig | ||||
* | Documentation to reflect patch from Eric Norum <eric@cls.usask.ca> to | Joel Sherrill | 2000-01-21 | 1 | -2/+11 |
| | | | | | the network initialization enhancement request by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added information about the NTP servier field and included a copy | Joel Sherrill | 1999-11-11 | 1 | -2/+68 |
| | | | | of the C definition of the configuration structure. | ||||
* | Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were | Joel Sherrill | 1999-10-25 | 1 | -11/+10 |
| | | | | backwards. | ||||
* | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1999-07-03 | 1 | -3/+67 |
| | | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | ||||
* | Updated socket information | Joel Sherrill | 1998-12-17 | 1 | -1/+2 |
* | Document from Ian Lance Taylor <ian@airs.com> on the tap function. | Joel Sherrill | 1998-12-10 | 1 | -0/+28 |
* | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1998-11-19 | 1 | -8/+9 |
* | Added some fields and changed last KA9Q reference to FreeBSD. | Joel Sherrill | 1998-10-12 | 1 | -1/+12 |
* | Fixed include file path. | Joel Sherrill | 1998-09-08 | 1 | -1/+1 |
* | Patch from Eric Norum | Joel Sherrill | 1998-08-21 | 1 | -10/+9 |
* | Update from Eric Norum. | Joel Sherrill | 1998-08-21 | 1 | -4/+23 |
* | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 1998-08-19 | 1 | -3/+3 |
* | Baseline | Joel Sherrill | 1998-08-19 | 1 | -0/+250 |
