* | Minor corrections from Nick Simon <Nick.SIMON@syntegra.bt.co.uk>. | Joel Sherrill | 2000-05-25 | 1 | -2/+2 |
| | | | | | | - char * nameserver[3] appears twice, second occurrence should be ntpserver - in sect 3.3.3 ...ifcontig should be ifconfig | ||||
* | Documentation to reflect patch from Eric Norum <eric@cls.usask.ca> to | Joel Sherrill | 2000-01-21 | 1 | -2/+11 |
| | | | | | the network initialization enhancement request by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added information about the NTP servier field and included a copy | Joel Sherrill | 1999-11-11 | 1 | -2/+68 |
| | | | | of the C definition of the configuration structure. | ||||
* | Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were | Joel Sherrill | 1999-10-25 | 1 | -11/+10 |
| | | | | backwards. | ||||
* | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1999-07-03 | 1 | -3/+67 |
| | | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | ||||
* | Updated socket information | Joel Sherrill | 1998-12-17 | 1 | -1/+2 |
* | Document from Ian Lance Taylor <ian@airs.com> on the tap function. | Joel Sherrill | 1998-12-10 | 1 | -0/+28 |
* | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1998-11-19 | 1 | -8/+9 |
* | Added some fields and changed last KA9Q reference to FreeBSD. | Joel Sherrill | 1998-10-12 | 1 | -1/+12 |
* | Fixed include file path. | Joel Sherrill | 1998-09-08 | 1 | -1/+1 |
* | Patch from Eric Norum | Joel Sherrill | 1998-08-21 | 1 | -10/+9 |
* | Update from Eric Norum. | Joel Sherrill | 1998-08-21 | 1 | -4/+23 |
* | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 1998-08-19 | 1 | -3/+3 |
* | Baseline | Joel Sherrill | 1998-08-19 | 1 | -0/+250 |
