2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-25 | Fixed line too long problems. | Joel Sherrill | 1 | -1/+2 | |
1999-04-19 | Comments from Eric Norum taken into account. | Joel Sherrill | 1 | -2/+14 | |
1999-04-19 | First cut at addition of information on macros that need to be defined. | Joel Sherrill | 1 | -0/+29 | |
1999-03-23 | Patch from Eric Norum to account for new routine that improved | Joel Sherrill | 1 | -9/+22 | |
parsing of interface names. | |||||
1998-12-17 | Incorporated Jeff's suggestions. | Joel Sherrill | 1 | -25/+28 | |
1998-11-19 | Applied updates from remote work while doing class. | Joel Sherrill | 1 | -1/+1 | |
1998-10-27 | Clarifed description of driver name. | Joel Sherrill | 1 | -1/+4 | |
1998-08-19 | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 1 | -1/+1 | |
1998-08-19 | Baseline | Joel Sherrill | 1 | -0/+281 | |
