path: root/doc/networking/decdriver.t (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-3/+0
* 2005-03-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-03-041-1/+1
| | | | | * networking/decdriver.t: Make PCI initialize function part of the unified PCI API as pci_initialize().
* 2004-07-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-07-311-28/+7
| | | | | | | * networking/networkflow.txt, networking/PCIreg.txt, networking/recvbd.txt: New. * networking/decdriver.t, networking/networktasks.t: Use @image for ASCII figures (Reflect changes above).
* Reformatted ASCII slightly to avoid line wrap.Joel Sherrill2000-05-281-3/+4
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-261-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Now includes figures.Joel Sherrill1999-10-071-12/+5
* Enabled PCI register figure and renamed them to avoid _ in name to avoidJoel Sherrill1999-10-061-12/+4
| | | | tool problems.
* Added DEC21140 document from Emmanuel Raguet <raguet@crf.canon.fr>.Joel Sherrill1999-04-081-4/+5
* First attempt to build.Joel Sherrill1999-04-081-264/+305
* New fileJoel Sherrill1999-04-081-0/+264
