* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -6/+7 |
* | COpy the images to the html install point. | Joel Sherrill | 1999-10-07 | 1 | -2/+6 |
| | | | | Added stanza to generate pdf files from eps ones. | ||||
* | Added convert stanza to generate pdf version of figures from eps. | Joel Sherrill | 1999-10-06 | 1 | -0/+3 |
* | Changing names to avoid the name of the document. | Joel Sherrill | 1999-10-06 | 1 | -2/+4 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -2/+7 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1999-07-03 | 1 | -1/+1 |
| | | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Added DEC21140 document from Emmanuel Raguet <raguet@crf.canon.fr>. | Joel Sherrill | 1999-04-08 | 1 | -1/+6 |
* | Added Network Servers Chapter including Jake Janovetz's ftpd server. | Joel Sherrill | 1999-04-02 | 1 | -1/+1 |
* | New file. Text from Jake Janovetz. | Joel Sherrill | 1999-04-01 | 1 | -1/+7 |
* | Changed the name of a section. | Joel Sherrill | 1999-02-09 | 1 | -1/+1 |
* | Changed version string. | Joel Sherrill | 1998-11-19 | 1 | -1/+1 |
| | | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | ||||
* | Removed chapter names from automatically generated node names. | Joel Sherrill | 1998-09-08 | 1 | -2/+4 |
* | First version produced. | Joel Sherrill | 1998-08-19 | 1 | -1/+1 |
* | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 1998-08-19 | 1 | -10/+10 |
* | Baseline | Joel Sherrill | 1998-08-19 | 1 | -0/+82 |
