* | Added timer manager. | Joel Sherrill | 2000-01-04 | 1 | -0/+5 |
* | Improved clean stanza. | Joel Sherrill | 2000-01-04 | 1 | -1/+1 |
* | Corrected spacing. | Joel Sherrill | 1999-11-17 | 1 | -8/+12 |
* | Correctd name of document produced for consistency. | Joel Sherrill | 1999-11-17 | 1 | -1/+1 |
* | Updated to reflect Mailbox Manager submission. | Joel Sherrill | 1999-11-17 | 1 | -3/+1 |
* | Changed name of document generated. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+14 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 2 | -6/+8 |
* | Added copyright. | Joel Sherrill | 1999-11-16 | 14 | -12/+62 |
* | Updated to include more documentation from CS595. | Joel Sherrill | 1999-11-10 | 5 | -22/+51 |
* | Better formatting. | Joel Sherrill | 1999-11-10 | 1 | -47/+75 |
* | Converted from DOS to UNIX filemode. | Joel Sherrill | 1999-11-09 | 3 | -1630/+1630 |
* | Corrected lines that were too long. | Joel Sherrill | 1999-11-09 | 2 | -8/+8 |
* | Fixed formatting error. | Joel Sherrill | 1999-11-09 | 1 | -1/+0 |
* | Corrected manual name. | Joel Sherrill | 1999-11-09 | 1 | -8/+8 |
* | Integrated into main tree. | Joel Sherrill | 1999-11-09 | 1 | -26/+15 |
* | Update from Jennifer. | Joel Sherrill | 1999-11-09 | 1 | -30/+54 |
* | Added more status information. | Joel Sherrill | 1999-11-09 | 1 | -0/+80 |
* | Added Status chapter. | Joel Sherrill | 1999-11-09 | 4 | -4/+1059 |
* | Corrected flaws which prevented formatting with texi2pdf since it | Joel Sherrill | 1999-11-09 | 1 | -1/+1 |
| | | | | is stricter on node names. | ||||
* | Final update from Santanu Mitra <smitra@cs.uah.edu>, T.N.S. Prasad | Joel Sherrill | 1999-08-11 | 2 | -499/+772 |
| | | | | | <ptelukun@cs.uah.edu>, and Wei He <whe@cs.uah.edu> on the Fixed Block and Memory Pool Managers. | ||||
* | Update from Andrew McDowell <drew@getaway.net>. DOS CR/LF, etc fixed | Joel Sherrill | 1999-08-02 | 1 | -19/+73 |
| | | | | by Joel. | ||||
* | Added comment on where this manager came from. | Joel Sherrill | 1999-07-13 | 1 | -1/+2 |
* | Update from Jeff Mayes, Jennifer Averett, and Suzie Provitt. | Joel Sherrill | 1999-07-13 | 1 | -17/+160 |
* | Update including fixes for my comments from Xiangyang Wu <wux@cspar.uah.edu> | Joel Sherrill | 1999-07-13 | 1 | -734/+858 |
| | | | | and xing@ebs330.eb.uah.edu. | ||||
* | Some cleanup to make it format better. Compensated for multiple services | Joel Sherrill | 1999-07-08 | 1 | -31/+142 |
| | | | | on a single page. | ||||
* | First draft from Xiangyang Wu <wux@cspar.uah.edu>. | Joel Sherrill | 1999-07-08 | 1 | -12/+351 |
* | From Fei Ling <fling@cs.uah.edu>. | Joel Sherrill | 1999-07-06 | 1 | -19/+524 |
* | Corrected and fleshed out. | Joel Sherrill | 1999-06-18 | 1 | -43/+2 |
* | Significantly cleaned up to make a much better starting point for the | Joel Sherrill | 1999-06-04 | 13 | -249/+361 |
| | | | | class. | ||||
* | Added much of the text required to turn this into a real chapter. | Joel Sherrill | 1999-06-04 | 1 | -52/+195 |
* | New file. | Joel Sherrill | 1999-05-26 | 1 | -0/+4 |
* | Made the gen_section more accurate. | Joel Sherrill | 1999-05-26 | 13 | -253/+257 |
* | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 1999-05-26 | 11 | -83/+166 |
| | | | | The style in the output is not right but it is a good starting point. | ||||
* | Basic prototypes are now included. | Joel Sherrill | 1999-05-26 | 1 | -1/+6 |
* | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 1999-05-26 | 12 | -180/+184 |
| | | | | the descriptive titles. | ||||
* | Changed word "directive" to "system call." | Joel Sherrill | 1999-05-26 | 1 | -1/+1 |
* | Added error codes to all service calls | Joel Sherrill | 1999-05-26 | 1 | -14/+190 |
* | Corrected error code section. | Joel Sherrill | 1999-05-26 | 12 | -168/+0 |
* | Replaced error code section. | Joel Sherrill | 1999-05-26 | 12 | -252/+84 |
* | Enhanced. | Joel Sherrill | 1999-05-26 | 1 | -63/+156 |
* | Initial revision | Joel Sherrill | 1999-05-20 | 16 | -0/+4561 |
