1999-07-13 | Update including fixes for my comments from Xiangyang Wu <wux@cspar.uah.edu> | Joel Sherrill | 1 | -734/+858 | |
and xing@ebs330.eb.uah.edu. | |||||
1999-07-08 | Some cleanup to make it format better. Compensated for multiple services | Joel Sherrill | 1 | -31/+142 | |
on a single page. | |||||
1999-07-08 | First draft from Xiangyang Wu <wux@cspar.uah.edu>. | Joel Sherrill | 1 | -12/+351 | |
1999-07-06 | From Fei Ling <fling@cs.uah.edu>. | Joel Sherrill | 1 | -19/+524 | |
1999-06-18 | Corrected and fleshed out. | Joel Sherrill | 1 | -43/+2 | |
1999-06-04 | Significantly cleaned up to make a much better starting point for the | Joel Sherrill | 13 | -249/+361 | |
class. | |||||
1999-06-04 | Added much of the text required to turn this into a real chapter. | Joel Sherrill | 1 | -52/+195 | |
1999-05-26 | New file. | Joel Sherrill | 1 | -0/+4 | |
1999-05-26 | Made the gen_section more accurate. | Joel Sherrill | 13 | -253/+257 | |
1999-05-26 | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 11 | -83/+166 | |
The style in the output is not right but it is a good starting point. | |||||
1999-05-26 | Basic prototypes are now included. | Joel Sherrill | 1 | -1/+6 | |
1999-05-26 | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 12 | -180/+184 | |
the descriptive titles. | |||||
1999-05-26 | Changed word "directive" to "system call." | Joel Sherrill | 1 | -1/+1 | |
1999-05-26 | Added error codes to all service calls | Joel Sherrill | 1 | -14/+190 | |
1999-05-26 | Corrected error code section. | Joel Sherrill | 12 | -168/+0 | |
1999-05-26 | Replaced error code section. | Joel Sherrill | 12 | -252/+84 | |
1999-05-26 | Enhanced. | Joel Sherrill | 1 | -63/+156 | |
1999-05-20 | Initial revision | Joel Sherrill | 16 | -0/+4561 | |
