* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 2 | -133/+100 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | ||||
* | Added timer manager. | Joel Sherrill | 2000-01-04 | 1 | -0/+5 |
* | Improved clean stanza. | Joel Sherrill | 2000-01-04 | 1 | -1/+1 |
* | Corrected spacing. | Joel Sherrill | 1999-11-17 | 1 | -8/+12 |
* | Correctd name of document produced for consistency. | Joel Sherrill | 1999-11-17 | 1 | -1/+1 |
* | Updated to reflect Mailbox Manager submission. | Joel Sherrill | 1999-11-17 | 1 | -3/+1 |
* | Changed name of document generated. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+14 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 2 | -6/+8 |
* | Added copyright. | Joel Sherrill | 1999-11-16 | 14 | -12/+62 |
* | Updated to include more documentation from CS595. | Joel Sherrill | 1999-11-10 | 5 | -22/+51 |
* | Better formatting. | Joel Sherrill | 1999-11-10 | 1 | -47/+75 |
* | Converted from DOS to UNIX filemode. | Joel Sherrill | 1999-11-09 | 3 | -1630/+1630 |
* | Corrected lines that were too long. | Joel Sherrill | 1999-11-09 | 2 | -8/+8 |
* | Fixed formatting error. | Joel Sherrill | 1999-11-09 | 1 | -1/+0 |
* | Corrected manual name. | Joel Sherrill | 1999-11-09 | 1 | -8/+8 |
* | Integrated into main tree. | Joel Sherrill | 1999-11-09 | 1 | -26/+15 |
* | Update from Jennifer. | Joel Sherrill | 1999-11-09 | 1 | -30/+54 |
* | Added more status information. | Joel Sherrill | 1999-11-09 | 1 | -0/+80 |
* | Added Status chapter. | Joel Sherrill | 1999-11-09 | 4 | -4/+1059 |
* | Corrected flaws which prevented formatting with texi2pdf since it | Joel Sherrill | 1999-11-09 | 1 | -1/+1 |
| | | | | is stricter on node names. | ||||
* | Final update from Santanu Mitra <smitra@cs.uah.edu>, T.N.S. Prasad | Joel Sherrill | 1999-08-11 | 2 | -499/+772 |
| | | | | | <ptelukun@cs.uah.edu>, and Wei He <whe@cs.uah.edu> on the Fixed Block and Memory Pool Managers. | ||||
* | Update from Andrew McDowell <drew@getaway.net>. DOS CR/LF, etc fixed | Joel Sherrill | 1999-08-02 | 1 | -19/+73 |
| | | | | by Joel. | ||||
* | Added comment on where this manager came from. | Joel Sherrill | 1999-07-13 | 1 | -1/+2 |
* | Update from Jeff Mayes, Jennifer Averett, and Suzie Provitt. | Joel Sherrill | 1999-07-13 | 1 | -17/+160 |
* | Update including fixes for my comments from Xiangyang Wu <wux@cspar.uah.edu> | Joel Sherrill | 1999-07-13 | 1 | -734/+858 |
| | | | | and xing@ebs330.eb.uah.edu. | ||||
* | Some cleanup to make it format better. Compensated for multiple services | Joel Sherrill | 1999-07-08 | 1 | -31/+142 |
| | | | | on a single page. | ||||
* | First draft from Xiangyang Wu <wux@cspar.uah.edu>. | Joel Sherrill | 1999-07-08 | 1 | -12/+351 |
* | From Fei Ling <fling@cs.uah.edu>. | Joel Sherrill | 1999-07-06 | 1 | -19/+524 |
* | Corrected and fleshed out. | Joel Sherrill | 1999-06-18 | 1 | -43/+2 |
* | Significantly cleaned up to make a much better starting point for the | Joel Sherrill | 1999-06-04 | 13 | -249/+361 |
| | | | | class. | ||||
* | Added much of the text required to turn this into a real chapter. | Joel Sherrill | 1999-06-04 | 1 | -52/+195 |
* | New file. | Joel Sherrill | 1999-05-26 | 1 | -0/+4 |
* | Made the gen_section more accurate. | Joel Sherrill | 1999-05-26 | 13 | -253/+257 |
* | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 1999-05-26 | 11 | -83/+166 |
| | | | | The style in the output is not right but it is a good starting point. | ||||
* | Basic prototypes are now included. | Joel Sherrill | 1999-05-26 | 1 | -1/+6 |
* | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 1999-05-26 | 12 | -180/+184 |
| | | | | the descriptive titles. | ||||
* | Changed word "directive" to "system call." | Joel Sherrill | 1999-05-26 | 1 | -1/+1 |
* | Added error codes to all service calls | Joel Sherrill | 1999-05-26 | 1 | -14/+190 |
* | Corrected error code section. | Joel Sherrill | 1999-05-26 | 12 | -168/+0 |
* | Replaced error code section. | Joel Sherrill | 1999-05-26 | 12 | -252/+84 |
* | Enhanced. | Joel Sherrill | 1999-05-26 | 1 | -63/+156 |
* | Initial revision | Joel Sherrill | 1999-05-20 | 16 | -0/+4561 |
