2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Added copyright. | Joel Sherrill | 1 | -0/+4 | |
1999-11-10 | Updated to include more documentation from CS595. | Joel Sherrill | 1 | -15/+13 | |
1999-11-09 | Converted from DOS to UNIX filemode. | Joel Sherrill | 1 | -858/+858 | |
1999-11-09 | Corrected lines that were too long. | Joel Sherrill | 1 | -5/+5 | |
1999-07-13 | Update including fixes for my comments from Xiangyang Wu <wux@cspar.uah.edu> | Joel Sherrill | 1 | -734/+858 | |
and xing@ebs330.eb.uah.edu. | |||||
1999-07-08 | Some cleanup to make it format better. Compensated for multiple services | Joel Sherrill | 1 | -31/+142 | |
on a single page. | |||||
1999-07-08 | First draft from Xiangyang Wu <wux@cspar.uah.edu>. | Joel Sherrill | 1 | -12/+351 | |
1999-06-04 | Significantly cleaned up to make a much better starting point for the | Joel Sherrill | 1 | -25/+38 | |
class. | |||||
1999-05-26 | Made the gen_section more accurate. | Joel Sherrill | 1 | -24/+24 | |
1999-05-26 | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 1 | -8/+16 | |
The style in the output is not right but it is a good starting point. | |||||
1999-05-26 | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 1 | -17/+17 | |
the descriptive titles. | |||||
1999-05-26 | Corrected error code section. | Joel Sherrill | 1 | -16/+0 | |
1999-05-26 | Replaced error code section. | Joel Sherrill | 1 | -24/+8 | |
1999-05-20 | Initial revision | Joel Sherrill | 1 | -36/+72 | |
1998-11-19 | Major update/merge of POSIX manual. | Joel Sherrill | 1 | -0/+0 | |
1998-09-29 | Added sentence to indicate sections were deliberately empty. | Joel Sherrill | 1 | -0/+4 | |
1998-08-04 | More complete shells generated. | Joel Sherrill | 1 | -8/+56 | |
1998-08-03 | Added many new chapters | Joel Sherrill | 1 | -72/+28 | |
1998-08-01 | New files -- automatically gnerated templates. | Joel Sherrill | 1 | -0/+251 | |
