path: root/doc/itron3.0/eventflags.t (follow)
* Update including fixes for my comments from Xiangyang Wu <wux@cspar.uah.edu>Joel Sherrill1999-07-131-734/+858
| | | | and xing@ebs330.eb.uah.edu.
* Some cleanup to make it format better. Compensated for multiple servicesJoel Sherrill1999-07-081-31/+142
| | | | on a single page.
* First draft from Xiangyang Wu <wux@cspar.uah.edu>.Joel Sherrill1999-07-081-12/+351
* Significantly cleaned up to make a much better starting point for theJoel Sherrill1999-06-041-25/+38
| | | | class.
* Made the gen_section more accurate.Joel Sherrill1999-05-261-24/+24
* Prototypes are now based on how the TRON specification states them.Joel Sherrill1999-05-261-8/+16
| | | | The style in the output is not right but it is a good starting point.
* Regenerated to include more information in the stub. Now they haveJoel Sherrill1999-05-261-17/+17
| | | | the descriptive titles.
* Corrected error code section.Joel Sherrill1999-05-261-16/+0
* Replaced error code section.Joel Sherrill1999-05-261-24/+8
* Initial revisionJoel Sherrill1999-05-201-0/+295
