path: root/doc/index.html.in (follow)
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-291-10/+0
| | | | | | * configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry, porting/cpumodels.t, started/buildc.t, started_ada/buildada.t, user/preface.texi: i960 obsoleted.
* 2004-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-041-1/+1
| | | | | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html, gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/require.t, started/sample.t, started/tversions.texi.in: Incorporating changes from pre-4.6.0 review.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-10/+0
| | | | | | * configure.ac, index.html.in: mips64orion port removed as mips port more completely covers the MIPS family. * rtems_support.html.in: Removed.
* 2003-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-221-14/+1
| | | | | | | PR 513/doc * Makefile.am, index.html.in: Rename Getting Started to be non-language specific and remove link to Ada Getting Started. Also install missing graphic.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-221-11/+0
| | | | | | | | | * Makefile.am: Merger from rtems-4-6-branch. * configure.ac: Merger from rtems-4-6-branch. Purge hppa1.1. * index.html.in: Purge hppa1.1. * project.am: Merger from rtems-4-6-branch. * rtems_support.html.in: Purge hppa1.1.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-191-3/+3
| | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, rtems_support.html.in, ada_user/ada_user.texi: Merge from branch. * acinclude.m4, images/rtems_logo.jpg: New files. * SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-111-1/+1
| | | | * index.html.in: Development Environment Guide should be updated now.
* 2003-02-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-181-1/+1
| | | | | | * Makefile.am, configure.ac: Remove src2html references. * index.html.in: Update to reflect partial update of Development Environment Guide.
* 2003-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-141-10/+0
| | | | * index.html.in: Removed a29k reference.
* 2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-271-10/+1
| | | | * index.html.in: Fix duplicate c4x entry.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-251-0/+10
| | | | * index.html.in: Add c4x.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-131-1/+5
| | | | | * index.html.in: Note that the Getting Started with GNAT/RTEMS manual is largely obsolete now that GNAT is in GCC.
* 2002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-241-19/+64
| | | | * index.html.in: Add links to multiple missing CPU supplements.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-3/+3
* Added out of date comment.Joel Sherrill2000-06-121-1/+1
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to:Joel Sherrill2000-06-011-6/+6
| | | | | | | | | | This patch changes the installation directory of the supplements to supplements/<cpu>. This allows browsing the html files inside of the source tree, because after having applied this patch, the structure of the html installation directory hierarchy is the same as the directory structure of the source tree.
* Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-06-011-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-261-0/+275
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
