* index.html.in: Fix duplicate c4x entry.
* index.html.in: Add c4x.
* index.html.in: Note that the Getting Started with GNAT/RTEMS
manual is largely obsolete now that GNAT is in GCC.
* index.html.in: Add links to multiple missing CPU supplements.
This patch changes the installation directory of the supplements to
supplements/<cpu>.
This allows browsing the html files inside of the source tree,
because after having applied this patch, the structure of the html
installation directory hierarchy is the same as the directory
structure of the source tree.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
