* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html,
gnu_docs/index.html, gnu_docs/refcard.html,
gnu_docs/rtems_tools_index.html, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/require.t, started/sample.t, started/tversions.texi.in:
Attempt to make the documentation more accurately reflect the state
of the world. These changes were primarily concerned with server
layout.
rtems_support.html.in, FAQ/basic.t, FAQ/build45.t,
bsp_howto/analog.t, bsp_howto/discrete.t, bsp_howto/nvmem.t,
bsp_howto/target.t, common/cpright.texi, gnu_docs/gnu_footer.html,
gnu_docs/gnu_header.html, gnu_docs/index.html, gnu_docs/refcard.html,
gnu_docs/rtems_tools_index.html, relnotes/install.texi,
relnotes/intro.texi, relnotes/status.texi, started/nextstep.t,
started_ada/intro.t, started_ada/tversions.texi: Migrate many
obsolete references from oarcorp.com to rtems.com. Also send people
to the support.html page rather than duplicate information.
* images/rtems_logo.jpg: New file.
* SUPPORT: Removed.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
that can be used to produce an online bookshelf of the GNU tools.
