* Makefile.am, configure.ac, develenv/direct.t: Remove gnu_docs. Now
included with RPMs.
* gnu_docs/.cvsignore, gnu_docs/ChangeLog, gnu_docs/Makefile.am,
gnu_docs/Tool_Doc_Instructions, gnu_docs/gen_docs,
gnu_docs/gnu_footer.html, gnu_docs/gnu_header.html,
gnu_docs/index.html, gnu_docs/mk_install_dir, gnu_docs/refcard.html,
gnu_docs/rtems_tools_index.html: Removed.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html,
gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html,
started/binaries.t, started/buildc.t, started/buildrt.t,
started/intro.t, started/require.t, started/sample.t,
started/tversions.texi.in: Incorporating changes from pre-4.6.0
review.
* gnu_footer.html, gnu_header.html, index.html, refcard.html,
rtems_tools_index.html: Merge from branch.
that can be used to produce an online bookshelf of the GNU tools.
