2017-01-11 | Remove texinfo format documentation. Replaced by Sphinx formatted documentation. | Joel Sherrill | 1 | -110/+0 | |
closes #2812. | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-12 | Made many changes to turn the outline into something more like a manual | Joel Sherrill | 1 | -5/+69 | |
and less like a collection of notes. | |||||
1999-10-11 | More cleanup. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Cleanup. | Joel Sherrill | 1 | -2/+2 | |
1999-10-08 | Another couple of chapters formatting under texinfo. | Joel Sherrill | 1 | -17/+32 | |
1999-10-08 | Added initial version of 3 other chapters. | Joel Sherrill | 1 | -3/+9 | |
1999-10-08 | Base versions cut from old document. | Joel Sherrill | 1 | -0/+28 | |
