* develenv/Makefile.am: Put *.texi into the builddir.
* ChangeLog: Reformat. Merge-in develenv/ChangeLog.
* develenv/ChangeLog: Remove.
* Makefile.am: Add direct.t sample.t utils.t to EXTRA_DIST.
* Makefile.am: Cosmetics.
* develenv.texi, direct.t, sample.t, utils.t: Merge from branch.
* Makefile.am, develenv.texi: Remove unused file.
* compile.texi: Removed.
* Makefile.am: Fix next/previous section names.
* direct.t, sample.t, utils.t: Significantly updated.
* .cvsignore: Add newly generated .texi files.
* Makefile.am, develenv.texi: Relect generating .texi from .t's.
* direct.t, sample.t, utils.t: New files.
* direct.texi, sample.texi, utils.texi: Removed. Now generated from
corresponding .t files which are in the process of being updated.
This commit is a anspshot of the update effort.
* develenv.texi: Set @setfilename develenv.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
pdf version of figures.
figures included.
