* | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 2008-12-04 | 4 | -4/+199 |
| | | | | | | * cpu_supplement/.cvsignore, cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi: Add Lattice Mico32 support. * cpu_supplement/lm32.t: New file. | ||||
* | 2008-06-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-06-02 | 12 | -2089/+693 |
| | | | | | | | | | | | | | * cpu_supplement/.cvsignore, cpu_supplement/Makefile.am, cpu_supplement/arm.t, cpu_supplement/bfin.t, cpu_supplement/cpu_supplement.texi, cpu_supplement/i386.t, cpu_supplement/m68k.t, cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/preface.texi, cpu_supplement/sh.t: Remove duplicated text from each CPU specific chapter. This text was necessary when each CPU was a separate manual but now only needs to be one place and that is in an introductory chapter. * cpu_supplement/general.t: New file. | ||||
* | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-04 | 8 | -339/+0 |
| | | | | | | | | | * cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t, cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/sh.t, cpu_supplement/sparc.t, cpu_supplement/tic4x.t, porting/cpuinit.t, user/conf.t, user/init.t: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | ||||
* | 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-03 | 8 | -509/+3 |
| | | | | | | | | | | | | * cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t, cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/sh.t, cpu_supplement/sparc.t, cpu_supplement/tic4x.t, user/conf.t: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred. | ||||
* | 2007-11-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-28 | 1 | -64/+8 |
| | | | | | | * cpu_supplement/powerpc.t: Eliminate PowerPC specific elements from the CPU Table. They have been replaced with variables named bsp_XXX as needed. | ||||
* | 2007-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-11-26 | 1 | -2/+0 |
| | | | | | | * cpu_supplement/sh.t: Eliminate the clicks_per_microsecond field in the SuperH CPU Table and define another mechanism for drivers to obtain this information. | ||||
* | 2007-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-11-26 | 2 | -11/+0 |
| | | | | | * cpu_supplement/i386.t, cpu_supplement/m68k.t: Pick up changes missed earlier. | ||||
* | 2007-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-11-26 | 1 | -1/+0 |
| | | | | | | * cpu_supplement/mips.t: Eliminate the clicks_per_microsecond field in the MIPS CPU Table and define another mechanism for drivers to obtain this information. | ||||
* | 2007-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-11-26 | 1 | -5/+3 |
| | | | | | | * cpu_supplement/i386.t: Eliminate the interrupt_table_segment and interrupt_table_offset fields in the i386 CPU Table since they are never read. | ||||
| | | | | | * cpu_supplement/m68k.t: Eliminate the interrupt_vector_table field in the m68k CPU Table since it is never read. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 1 | -1/+2 |
| | | | | | | | | | | | | * ada_user/ada_user.texi, bsp_howto/bsp_howto.texi, cpu_supplement/cpu_supplement.texi, develenv/develenv.texi, filesystem/filesystem.texi, itron3.0/itron.texi, networking/networking.texi, porting/porting.texi, posix1003.1/posix1003_1.texi, posix_users/posix_users.texi, rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi, started/started.texi, started_ada/started_ada.texi, user/c_user.texi: Print table of contents in front of manual where it should be when you print. | ||||
* | 2006-10-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-10-26 | 1 | -0/+12 |
| | | | | | | | * ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore, develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore, networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore, posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files. | ||||
* | 2006-10-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-10-23 | 4 | -4/+211 |
| | | | | | | | | * ada_user/Makefile.am, ada_user/ada_user.texi, cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi, cpu_supplement/sparc.t: Add Blackfin CPU supplement chapter and get everything building from previous breakages. * cpu_supplement/bfin.t: New file. | ||||
* | 2006-08-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-29 | 1 | -0/+109 |
| | | | | * cpu_supplement/cpu_supplement.texi: New file. | ||||
* | 2006-08-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-23 | 11 | -0/+6616 |
* Makefile.am, configure.ac, FAQ/stamp-vti, FAQ/version.texi, common/cpright.texi: Merging CPU Supplements into a single document. As part of this removed the obsolete and impossible to maintain size and timing information. * cpu_supplement/.cvsignore, cpu_supplement/Makefile.am, cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t, cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/preface.texi, cpu_supplement/sh.t, cpu_supplement/sparc.t, cpu_supplement/tic4x.t: New files. * supplements/.cvsignore, supplements/Makefile.am, supplements/supplement.am, supplements/arm/.cvsignore, supplements/arm/BSP_TIMES, supplements/arm/ChangeLog, supplements/arm/Makefile.am, supplements/arm/arm.texi, supplements/arm/bsp.t, supplements/arm/callconv.t, supplements/arm/cpumodel.t, supplements/arm/cputable.t, supplements/arm/fatalerr.t, supplements/arm/intr_NOTIMES.t, supplements/arm/memmodel.t, supplements/arm/preface.texi, supplements/arm/timeBSP.t, supplements/c4x/.cvsignore, supplements/c4x/BSP_TIMES, supplements/c4x/ChangeLog, supplements/c4x/Makefile.am, supplements/c4x/bsp.t, supplements/c4x/c4x.texi, supplements/c4x/callconv.t, supplements/c4x/cpumodel.t, supplements/c4x/cputable.t, supplements/c4x/fatalerr.t, supplements/c4x/intr_NOTIMES.t, supplements/c4x/memmodel.t, supplements/c4x/preface.texi, supplements/c4x/timeBSP.t, supplements/i386/.cvsignore, supplements/i386/ChangeLog, supplements/i386/FORCE386_TIMES, supplements/i386/Makefile.am, supplements/i386/bsp.t, supplements/i386/callconv.t, supplements/i386/cpumodel.t, supplements/i386/cputable.t, supplements/i386/fatalerr.t, supplements/i386/i386.texi, supplements/i386/intr_NOTIMES.t, supplements/i386/memmodel.t, supplements/i386/preface.texi, supplements/i386/timeFORCE386.t, supplements/m68k/.cvsignore, supplements/m68k/ChangeLog, supplements/m68k/MVME136_TIMES, supplements/m68k/Makefile.am, supplements/m68k/bsp.t, supplements/m68k/callconv.t, supplements/m68k/cpumodel.t, supplements/m68k/cputable.t, supplements/m68k/fatalerr.t, supplements/m68k/intr_NOTIMES.t, supplements/m68k/m68k.texi, supplements/m68k/memmodel.t, supplements/m68k/preface.texi, supplements/m68k/timeMVME136.t, supplements/m68k/timedata.t, supplements/mips/.cvsignore, supplements/mips/BSP_TIMES, supplements/mips/ChangeLog, supplements/mips/Makefile.am, supplements/mips/bsp.t, supplements/mips/callconv.t, supplements/mips/cpumodel.t, supplements/mips/cputable.t, supplements/mips/fatalerr.t, supplements/mips/intr_NOTIMES.t, supplements/mips/memmodel.t, supplements/mips/mips.texi, supplements/mips/preface.texi, supplements/mips/timeBSP.t, supplements/powerpc/.cvsignore, supplements/powerpc/ChangeLog, supplements/powerpc/DMV177_TIMES, supplements/powerpc/Makefile.am, supplements/powerpc/PSIM_TIMES, supplements/powerpc/bsp.t, supplements/powerpc/callconv.t, supplements/powerpc/cpumodel.t, supplements/powerpc/cputable.t, supplements/powerpc/fatalerr.t, supplements/powerpc/intr_NOTIMES.t, supplements/powerpc/memmodel.t, supplements/powerpc/powerpc.texi, supplements/powerpc/preface.texi, supplements/powerpc/timeDMV177.t, supplements/powerpc/timePSIM.t, supplements/sh/.cvsignore, supplements/sh/BSP_TIMES, supplements/sh/ChangeLog, supplements/sh/Makefile.am, supplements/sh/bsp.t, supplements/sh/callconv.t, supplements/sh/cpumodel.t, supplements/sh/cputable.t, supplements/sh/fatalerr.t, supplements/sh/intr_NOTIMES.t, supplements/sh/memmodel.t, supplements/sh/preface.texi, supplements/sh/sh.texi, supplements/sh/timeBSP.t, supplements/sparc/.cvsignore, supplements/sparc/ChangeLog, supplements/sparc/ERC32_TIMES, supplements/sparc/Makefile.am, supplements/sparc/bsp.t, supplements/sparc/callconv.t, supplements/sparc/cpumodel.t, supplements/sparc/cputable.t, supplements/sparc/fatalerr.t, supplements/sparc/intr_NOTIMES.t, supplements/sparc/memmodel.t, supplements/sparc/preface.texi, supplements/sparc/sparc.texi, supplements/sparc/timeERC32.t, supplements/template/.cvsignore, supplements/template/BSP_TIMES, supplements/template/ChangeLog, supplements/template/Makefile.am, supplements/template/bsp.t, supplements/template/callconv.t, supplements/template/cpumodel.t, supplements/template/cputable.t, supplements/template/fatalerr.t, supplements/template/intr_NOTIMES.t, supplements/template/memmodel.t, supplements/template/preface.texi, supplements/template/template.texi, supplements/template/timeBSP.t: Removed. |
