PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
PR 1752/doc
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/cpu_supplement.texi: Remove TI C4x CPU Supplement
chapter.
* cpu_supplement/tic4x.t: Removed.
PR 1565/cpukit
* cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi: Merge
SPARC64 port.
* cpu_supplement/sparc64.t: New file.
cpu_supplement/cpu_supplement.texi: Add shell for Atmel AVR chapter.
* cpu_supplement/avr.t: New file.
cpu_supplement/cpu_supplement.texi: Add Lattice Mico32 support.
* cpu_supplement/lm32.t: New file.
cpu_supplement/arm.t, cpu_supplement/bfin.t,
cpu_supplement/cpu_supplement.texi, cpu_supplement/i386.t,
cpu_supplement/m68k.t, cpu_supplement/mips.t,
cpu_supplement/powerpc.t, cpu_supplement/preface.texi,
cpu_supplement/sh.t: Remove duplicated text from each CPU specific
chapter. This text was necessary when each CPU was a separate manual
but now only needs to be one place and that is in an introductory
chapter.
* cpu_supplement/general.t: New file.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* ada_user/Makefile.am, ada_user/ada_user.texi,
cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi,
cpu_supplement/sparc.t: Add Blackfin CPU supplement chapter and get
everything building from previous breakages.
* cpu_supplement/bfin.t: New file.
* cpu_supplement/cpu_supplement.texi: New file.
