* fix and remove some macros in rtems.texi.in.
* refer to devel mailing list.
* remove reference to Debian packaging in requirements section.
* remove section on prebuilt tools.
* replace toolset build instructions with link to RSB docs.
* Add a note in building RTEMS section about using RSB.
* Fix URLs
Closes #2291.
* index.html.in, common/opengroup_manpage_acknowledgement.texi,
common/opengroup_preface_acknowledgement.texi: New dates.
* rtems_footer.html.in, common/cpright.texi: Update dates in copyright.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
* posix_users/preface.texi, shell/preface.texi: Add stock
acknowledgement paragraphs that are required when excerpting and
reusing text from POSIX standards per the agreement at
* common/opengroup_manpage_acknowledgement.texi,
common/opengroup_preface_acknowledgement.texi: New files.
* rtems_footer.html.in, common/cpright.texi: Update copyright. Fix
spacing.
* common/rtems.texi.in: Use bugzilla for RTEMSBUGS.
Remove RTEMSGNATS.
* Makefile.am, configure.ac, index.html.in: FAQ should now be
completely in the Wiki.
* FAQ/.cvsignore, FAQ/FAQ.texi, FAQ/Makefile.am, FAQ/basic.t,
FAQ/bsp.t, FAQ/build45.t, FAQ/concepts.t, FAQ/debug.t,
FAQ/endoftime.t, FAQ/entry, FAQ/freesw.t, FAQ/hwdebugaids.t,
FAQ/projects.t, FAQ/stamp-vti, FAQ/tools.t, FAQ/version.texi,
common/timemac.texi, common/timetbl.t, common/timing.t: Removed.
* Makefile.am, configure.ac, FAQ/stamp-vti, FAQ/version.texi,
common/cpright.texi: Merging CPU Supplements into a single document.
As part of this removed the obsolete and impossible to maintain size
and timing information.
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t,
cpu_supplement/mips.t, cpu_supplement/powerpc.t,
cpu_supplement/preface.texi, cpu_supplement/sh.t,
cpu_supplement/sparc.t, cpu_supplement/tic4x.t: New files.
* supplements/.cvsignore, supplements/Makefile.am,
supplements/supplement.am, supplements/arm/.cvsignore,
supplements/arm/BSP_TIMES, supplements/arm/ChangeLog,
supplements/arm/Makefile.am, supplements/arm/arm.texi,
supplements/arm/bsp.t, supplements/arm/callconv.t,
supplements/arm/cpumodel.t, supplements/arm/cputable.t,
supplements/arm/fatalerr.t, supplements/arm/intr_NOTIMES.t,
supplements/arm/memmodel.t, supplements/arm/preface.texi,
supplements/arm/timeBSP.t, supplements/c4x/.cvsignore,
supplements/c4x/BSP_TIMES, supplements/c4x/ChangeLog,
supplements/c4x/Makefile.am, supplements/c4x/bsp.t,
supplements/c4x/c4x.texi, supplements/c4x/callconv.t,
supplements/c4x/cpumodel.t, supplements/c4x/cputable.t,
supplements/c4x/fatalerr.t, supplements/c4x/intr_NOTIMES.t,
supplements/c4x/memmodel.t, supplements/c4x/preface.texi,
supplements/c4x/timeBSP.t, supplements/i386/.cvsignore,
supplements/i386/ChangeLog, supplements/i386/FORCE386_TIMES,
supplements/i386/Makefile.am, supplements/i386/bsp.t,
supplements/i386/callconv.t, supplements/i386/cpumodel.t,
supplements/i386/cputable.t, supplements/i386/fatalerr.t,
supplements/i386/i386.texi, supplements/i386/intr_NOTIMES.t,
supplements/i386/memmodel.t, supplements/i386/preface.texi,
supplements/i386/timeFORCE386.t, supplements/m68k/.cvsignore,
supplements/m68k/ChangeLog, supplements/m68k/MVME136_TIMES,
supplements/m68k/Makefile.am, supplements/m68k/bsp.t,
supplements/m68k/callconv.t, supplements/m68k/cpumodel.t,
supplements/m68k/cputable.t, supplements/m68k/fatalerr.t,
supplements/m68k/intr_NOTIMES.t, supplements/m68k/m68k.texi,
supplements/m68k/memmodel.t, supplements/m68k/preface.texi,
supplements/m68k/timeMVME136.t, supplements/m68k/timedata.t,
supplements/mips/.cvsignore, supplements/mips/BSP_TIMES,
supplements/mips/ChangeLog, supplements/mips/Makefile.am,
supplements/mips/bsp.t, supplements/mips/callconv.t,
supplements/mips/cpumodel.t, supplements/mips/cputable.t,
supplements/mips/fatalerr.t, supplements/mips/intr_NOTIMES.t,
supplements/mips/memmodel.t, supplements/mips/mips.texi,
supplements/mips/preface.texi, supplements/mips/timeBSP.t,
supplements/powerpc/.cvsignore, supplements/powerpc/ChangeLog,
supplements/powerpc/DMV177_TIMES, supplements/powerpc/Makefile.am,
supplements/powerpc/PSIM_TIMES, supplements/powerpc/bsp.t,
supplements/powerpc/callconv.t, supplements/powerpc/cpumodel.t,
supplements/powerpc/cputable.t, supplements/powerpc/fatalerr.t,
supplements/powerpc/intr_NOTIMES.t, supplements/powerpc/memmodel.t,
supplements/powerpc/powerpc.texi, supplements/powerpc/preface.texi,
supplements/powerpc/timeDMV177.t, supplements/powerpc/timePSIM.t,
supplements/sh/.cvsignore, supplements/sh/BSP_TIMES,
supplements/sh/ChangeLog, supplements/sh/Makefile.am,
supplements/sh/bsp.t, supplements/sh/callconv.t,
supplements/sh/cpumodel.t, supplements/sh/cputable.t,
supplements/sh/fatalerr.t, supplements/sh/intr_NOTIMES.t,
supplements/sh/memmodel.t, supplements/sh/preface.texi,
supplements/sh/sh.texi, supplements/sh/timeBSP.t,
supplements/sparc/.cvsignore, supplements/sparc/ChangeLog,
supplements/sparc/ERC32_TIMES, supplements/sparc/Makefile.am,
supplements/sparc/bsp.t, supplements/sparc/callconv.t,
supplements/sparc/cpumodel.t, supplements/sparc/cputable.t,
supplements/sparc/fatalerr.t, supplements/sparc/intr_NOTIMES.t,
supplements/sparc/memmodel.t, supplements/sparc/preface.texi,
supplements/sparc/sparc.texi, supplements/sparc/timeERC32.t,
supplements/template/.cvsignore, supplements/template/BSP_TIMES,
supplements/template/ChangeLog, supplements/template/Makefile.am,
supplements/template/bsp.t, supplements/template/callconv.t,
supplements/template/cpumodel.t, supplements/template/cputable.t,
supplements/template/fatalerr.t, supplements/template/intr_NOTIMES.t,
supplements/template/memmodel.t, supplements/template/preface.texi,
supplements/template/template.texi, supplements/template/timeBSP.t: Removed.
* common/rtems.texi.in, FAQ/basic.t: Remove RTEMSSNAPSHOTS,
RTEMSSNAPSHOTSSUBSCRIBE.
* configure.ac: Add RTEMSRPMGROUP.
* common/rtems.texi.in: Add RTEMSRPMGROUP.
* started/binaries.t: Add RTEMSRPMGROUP.
* configure.ac: Add RTEMS_ENABLE_RPMPREFIX.
Add RTEMSRPMPREFIX.
* common/rtems.texi.in: Add RTEMSRPMPREFIX.
* common/ChangeLog: Removed.
* ChangeLog: Merge common/ChangeLog.
* common/.cvsignore: Add rtems.texi, rtems.sed.
* cpright.texi, setup.texi: Merge from branch.
* rtems.texi.in: New file.
* Makefile.am: Merge-in images/Makefile.am, common/Makefile.am.
* images/Makefile.am: Remove.
* common/Makefile.am: Remove.
* main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
