path: root/doc/common (follow)
* 2004-07-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-07-311-2/+0
| | | | | * common/rtems.texi.in, FAQ/basic.t: Remove RTEMSSNAPSHOTS, RTEMSSNAPSHOTSSUBSCRIBE.
* Remove refs to Makefile*.Ralf Corsepius2004-03-091-2/+0
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-0/+1
| | | | | | * configure.ac: Add RTEMSRPMGROUP. * common/rtems.texi.in: Add RTEMSRPMGROUP. * started/binaries.t: Add RTEMSRPMGROUP.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-1/+1
| | | | | | * configure.ac: Add RTEMS_ENABLE_RPMPREFIX. Add RTEMSRPMPREFIX. * common/rtems.texi.in: Add RTEMSRPMPREFIX.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-221-16/+0
| | | | | * common/ChangeLog: Removed. * ChangeLog: Merge common/ChangeLog.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-221-0/+2
| | | | * common/.cvsignore: Add rtems.texi, rtems.sed.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-194-14/+26
| | | | | * cpright.texi, setup.texi: Merge from branch. * rtems.texi.in: New file.
* 2002-12-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-081-6/+0
| | | | | | | | * Makefile.am: Merge-in images/Makefile.am, common/Makefile.am. * images/Makefile.am: Remove. * common/Makefile.am: Remove. * configure.ac: Reflect changes above. * main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-282-1/+4
| | | | * Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-182-1/+5
| | | | * Makefile.am: Require automake-1.5.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-176-8/+10
* Adding ChangeLogs.Joel Sherrill2000-08-251-0/+3
* Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill2000-06-141-2/+2
| | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
* Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-101-4/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
* Readding.Joel Sherrill2000-06-011-0/+65
* Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-06-012-76/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
* Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2000-05-012-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
* New files. First attempt.Joel Sherrill2000-04-271-0/+3
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-269-5/+13
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Merged changes from 4.5 branch and removed that branch.Joel Sherrill2000-04-251-4/+4
* Changed to 4.5.0-beta1b.Joel Sherrill2000-02-231-5/+5
* Updated dates and miscellaneous.Joel Sherrill2000-01-041-5/+5
* New date.Joel Sherrill1999-11-171-4/+4
* Changed copyright date to 1999.Joel Sherrill1999-11-166-6/+6
* Changed release date.Joel Sherrill1999-11-161-5/+5
* Changed version timestamp.Joel Sherrill1999-10-281-1/+1
* Changed release information.Joel Sherrill1999-10-111-5/+5
* New files.Joel Sherrill1999-10-114-0/+0
* Updated version numbers.Joel Sherrill1999-08-201-5/+5
* Updated versionJoel Sherrill1999-07-091-5/+5
* Changed date.Joel Sherrill1999-04-231-5/+5
* Changed dates.Joel Sherrill1999-04-021-3/+3
* Changed versions.Joel Sherrill1999-02-101-5/+5
* Changed version.Joel Sherrill1999-02-091-5/+5
* Changed date.Joel Sherrill1999-02-091-1/+1
* Changed version string.Joel Sherrill1998-11-191-5/+5
| | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk.
* Version changed.Joel Sherrill1998-10-271-3/+3
* Version changed.Joel Sherrill1998-10-271-4/+4
* Removed node information.Joel Sherrill1998-10-191-28/+1
* Removed node information now that it is automatically generated.Joel Sherrill1998-10-191-42/+0
* Changed version and date strings.Joel Sherrill1998-10-191-5/+5
* Renamed so the menu structure can be built on the fly.Joel Sherrill1998-10-191-65/+2
* Changed version.Joel Sherrill1998-08-211-2/+2
* Switched from generating tables based on CPU model to BSP.Joel Sherrill1998-08-201-14/+14
* Changed version.Joel Sherrill1998-08-201-5/+5
* New dates and versions.Joel Sherrill1998-08-131-5/+5
* Changed phone number to reflect new area code.Joel Sherrill1998-08-131-2/+2
* Changed version and dateJoel Sherrill1998-04-131-5/+5
* Moved to tools/texi2www since they are part of that distribution.Joel Sherrill1998-04-034-0/+0
* Mediocre graphic just to use as a place holder to show what it looks like.Joel Sherrill1998-03-301-0/+0
