path: root/doc/common/setup.texi (unfollow)
2000-06-14Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill1-2/+2
<corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
2000-06-01Readding.Joel Sherrill1-0/+65
2000-04-26Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-75/+0
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
2000-04-25Merged changes from 4.5 branch and removed that branch.Joel Sherrill1-4/+4
2000-02-23Changed to 4.5.0-beta1b.Joel Sherrill1-5/+5
2000-01-04Updated dates and miscellaneous.Joel Sherrill1-5/+5
1999-11-17New date.Joel Sherrill1-4/+4
1999-11-16Changed copyright date to 1999.Joel Sherrill1-1/+1
1999-11-16Changed release date.Joel Sherrill1-5/+5
1999-10-28Changed version timestamp.Joel Sherrill1-1/+1
1999-10-11Changed release information.Joel Sherrill1-5/+5
1999-08-20Updated version numbers.Joel Sherrill1-5/+5
1999-07-09Updated versionJoel Sherrill1-5/+5
1999-04-23Changed date.Joel Sherrill1-5/+5
1999-04-02Changed dates.Joel Sherrill1-3/+3
1999-02-10Changed versions.Joel Sherrill1-5/+5
1999-02-09Changed version.Joel Sherrill1-5/+5
1998-11-19Changed version string.Joel Sherrill1-5/+5
Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk.
1998-10-27Version changed.Joel Sherrill1-3/+3
1998-10-27Version changed.Joel Sherrill1-4/+4
1998-10-19Changed version and date strings.Joel Sherrill1-5/+5
1998-08-21Changed version.Joel Sherrill1-2/+2
1998-08-20Changed version.Joel Sherrill1-5/+5
1998-08-13New dates and versions.Joel Sherrill1-5/+5
1998-04-13Changed version and dateJoel Sherrill1-5/+5
1998-03-26Added variables for dates and revision infoJoel Sherrill1-1/+5
1998-02-06Updated copyrightsJoel Sherrill1-1/+1
1997-06-04added CVS Id stringJoel Sherrill1-0/+2
1997-06-04changed edition and version informationJoel Sherrill1-1/+1
1997-05-28*** empty log message ***Joel Sherrill1-1/+1
1997-05-27Initial revisionJoel Sherrill1-0/+69
