2000-06-01 | Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -75/+0 | |
Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc. | |||||
2000-05-01 | Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -2/+2 | |
It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to. | |||||
2000-04-26 | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -4/+4 | |
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | |||||
2000-04-25 | Merged changes from 4.5 branch and removed that branch. | Joel Sherrill | 1 | -4/+4 | |
2000-02-23 | Changed to 4.5.0-beta1b. | Joel Sherrill | 1 | -5/+5 | |
2000-01-04 | Updated dates and miscellaneous. | Joel Sherrill | 1 | -5/+5 | |
1999-11-17 | New date. | Joel Sherrill | 1 | -4/+4 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Changed release date. | Joel Sherrill | 1 | -5/+5 | |
1999-10-28 | Changed version timestamp. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Changed release information. | Joel Sherrill | 1 | -5/+5 | |
1999-08-20 | Updated version numbers. | Joel Sherrill | 1 | -5/+5 | |
1999-07-09 | Updated version | Joel Sherrill | 1 | -5/+5 | |
1999-04-23 | Changed date. | Joel Sherrill | 1 | -5/+5 | |
1999-04-02 | Changed dates. | Joel Sherrill | 1 | -3/+3 | |
1999-02-10 | Changed versions. | Joel Sherrill | 1 | -5/+5 | |
1999-02-09 | Changed version. | Joel Sherrill | 1 | -5/+5 | |
1998-11-19 | Changed version string. | Joel Sherrill | 1 | -5/+5 | |
Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | |||||
1998-10-27 | Version changed. | Joel Sherrill | 1 | -3/+3 | |
1998-10-27 | Version changed. | Joel Sherrill | 1 | -4/+4 | |
1998-10-19 | Changed version and date strings. | Joel Sherrill | 1 | -5/+5 | |
1998-08-21 | Changed version. | Joel Sherrill | 1 | -2/+2 | |
1998-08-20 | Changed version. | Joel Sherrill | 1 | -5/+5 | |
1998-08-13 | New dates and versions. | Joel Sherrill | 1 | -5/+5 | |
1998-04-13 | Changed version and date | Joel Sherrill | 1 | -5/+5 | |
1998-03-26 | Added variables for dates and revision info | Joel Sherrill | 1 | -1/+5 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-06-04 | changed edition and version information | Joel Sherrill | 1 | -1/+1 | |
1997-05-28 | *** empty log message *** | Joel Sherrill | 1 | -1/+1 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+69 | |
