* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
* common/rtems.texi.in: Use bugzilla for RTEMSBUGS.
Remove RTEMSGNATS.
* common/rtems.texi.in, FAQ/basic.t: Remove RTEMSSNAPSHOTS,
RTEMSSNAPSHOTSSUBSCRIBE.
* configure.ac: Add RTEMSRPMGROUP.
* common/rtems.texi.in: Add RTEMSRPMGROUP.
* started/binaries.t: Add RTEMSRPMGROUP.
* configure.ac: Add RTEMS_ENABLE_RPMPREFIX.
Add RTEMSRPMPREFIX.
* common/rtems.texi.in: Add RTEMSRPMPREFIX.
* cpright.texi, setup.texi: Merge from branch.
* rtems.texi.in: New file.
