path: root/doc/common/opengroup_preface_acknowledgement.texi (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-3/+0
* 2011-05-12 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-05-121-1/+1
| | | | | * index.html.in, common/opengroup_manpage_acknowledgement.texi, common/opengroup_preface_acknowledgement.texi: New dates.
* 2009-02-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-02-271-0/+40
* posix_users/preface.texi, shell/preface.texi: Add stock acknowledgement paragraphs that are required when excerpting and reusing text from POSIX standards per the agreement at * common/opengroup_manpage_acknowledgement.texi, common/opengroup_preface_acknowledgement.texi: New files.
