path: root/doc/common/opengroup_manpage_acknowledgement.texi (unfollow)
2017-01-11Remove texinfo format documentation. Replaced by Sphinx formatted documentation.Joel Sherrill1-32/+0
closes #2812.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-3/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-05-122011-05-12 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill1-1/+1
* index.html.in, common/opengroup_manpage_acknowledgement.texi, common/opengroup_preface_acknowledgement.texi: New dates.
2009-02-272009-02-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+35
* posix_users/preface.texi, shell/preface.texi: Add stock acknowledgement paragraphs that are required when excerpting and reusing text from POSIX standards per the agreement at * common/opengroup_manpage_acknowledgement.texi, common/opengroup_preface_acknowledgement.texi: New files.
