2017-01-11 | Remove texinfo format documentation. Replaced by Sphinx formatted documentation. | Joel Sherrill | 1 | -39/+0 | |
closes #2812. | |||||
2015-07-17 | Update date | Joel Sherrill | 1 | -2/+2 | |
2014-03-20 | cpright.texi: Update to reflect services and community | Joel Sherrill | 1 | -7/+9 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -2/+2 | |
2014-03-11 | cpright.texi: Update to 2014. | Joel Sherrill | 1 | -1/+1 | |
2013-02-26 | doc: Update copyright year in common files | Joel Sherrill | 1 | -2/+2 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-02-03 | Update copyright year on manuals to 2012. | Joel Sherrill | 1 | -2/+2 | |
2011-04-07 | 2011-04-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* rtems_footer.html.in, common/cpright.texi: Update dates in copyright. | |||||
2010-12-14 | 2010-12-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -3/+3 | |
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in, cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/nextstep.t, started/nt.t, started/require.t, started/sample.t, started/started.texi, started/version.texi: Major update which includes removal of references to specific tool versions and patches. * started/tversions.texi.in: Removed. | |||||
2008-01-25 | 2008-01-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* rtems_footer.html.in, common/cpright.texi: Update copyright. Fix spacing. | |||||
2007-09-04 | 2007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* rtems_footer.html.in, common/cpright.texi: Update copyright. | |||||
2006-08-23 | 2006-08-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* Makefile.am, configure.ac, FAQ/stamp-vti, FAQ/version.texi, common/cpright.texi: Merging CPU Supplements into a single document. As part of this removed the obsolete and impossible to maintain size and timing information. * cpu_supplement/.cvsignore, cpu_supplement/Makefile.am, cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t, cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/preface.texi, cpu_supplement/sh.t, cpu_supplement/sparc.t, cpu_supplement/tic4x.t: New files. * supplements/.cvsignore, supplements/Makefile.am, supplements/supplement.am, supplements/arm/.cvsignore, supplements/arm/BSP_TIMES, supplements/arm/ChangeLog, supplements/arm/Makefile.am, supplements/arm/arm.texi, supplements/arm/bsp.t, supplements/arm/callconv.t, supplements/arm/cpumodel.t, supplements/arm/cputable.t, supplements/arm/fatalerr.t, supplements/arm/intr_NOTIMES.t, supplements/arm/memmodel.t, supplements/arm/preface.texi, supplements/arm/timeBSP.t, supplements/c4x/.cvsignore, supplements/c4x/BSP_TIMES, supplements/c4x/ChangeLog, supplements/c4x/Makefile.am, supplements/c4x/bsp.t, supplements/c4x/c4x.texi, supplements/c4x/callconv.t, supplements/c4x/cpumodel.t, supplements/c4x/cputable.t, supplements/c4x/fatalerr.t, supplements/c4x/intr_NOTIMES.t, supplements/c4x/memmodel.t, supplements/c4x/preface.texi, supplements/c4x/timeBSP.t, supplements/i386/.cvsignore, supplements/i386/ChangeLog, supplements/i386/FORCE386_TIMES, supplements/i386/Makefile.am, supplements/i386/bsp.t, supplements/i386/callconv.t, supplements/i386/cpumodel.t, supplements/i386/cputable.t, supplements/i386/fatalerr.t, supplements/i386/i386.texi, supplements/i386/intr_NOTIMES.t, supplements/i386/memmodel.t, supplements/i386/preface.texi, supplements/i386/timeFORCE386.t, supplements/m68k/.cvsignore, supplements/m68k/ChangeLog, supplements/m68k/MVME136_TIMES, supplements/m68k/Makefile.am, supplements/m68k/bsp.t, supplements/m68k/callconv.t, supplements/m68k/cpumodel.t, supplements/m68k/cputable.t, supplements/m68k/fatalerr.t, supplements/m68k/intr_NOTIMES.t, supplements/m68k/m68k.texi, supplements/m68k/memmodel.t, supplements/m68k/preface.texi, supplements/m68k/timeMVME136.t, supplements/m68k/timedata.t, supplements/mips/.cvsignore, supplements/mips/BSP_TIMES, supplements/mips/ChangeLog, supplements/mips/Makefile.am, supplements/mips/bsp.t, supplements/mips/callconv.t, supplements/mips/cpumodel.t, supplements/mips/cputable.t, supplements/mips/fatalerr.t, supplements/mips/intr_NOTIMES.t, supplements/mips/memmodel.t, supplements/mips/mips.texi, supplements/mips/preface.texi, supplements/mips/timeBSP.t, supplements/powerpc/.cvsignore, supplements/powerpc/ChangeLog, supplements/powerpc/DMV177_TIMES, supplements/powerpc/Makefile.am, supplements/powerpc/PSIM_TIMES, supplements/powerpc/bsp.t, supplements/powerpc/callconv.t, supplements/powerpc/cpumodel.t, supplements/powerpc/cputable.t, supplements/powerpc/fatalerr.t, supplements/powerpc/intr_NOTIMES.t, supplements/powerpc/memmodel.t, supplements/powerpc/powerpc.texi, supplements/powerpc/preface.texi, supplements/powerpc/timeDMV177.t, supplements/powerpc/timePSIM.t, supplements/sh/.cvsignore, supplements/sh/BSP_TIMES, supplements/sh/ChangeLog, supplements/sh/Makefile.am, supplements/sh/bsp.t, supplements/sh/callconv.t, supplements/sh/cpumodel.t, supplements/sh/cputable.t, supplements/sh/fatalerr.t, supplements/sh/intr_NOTIMES.t, supplements/sh/memmodel.t, supplements/sh/preface.texi, supplements/sh/sh.texi, supplements/sh/timeBSP.t, supplements/sparc/.cvsignore, supplements/sparc/ChangeLog, supplements/sparc/ERC32_TIMES, supplements/sparc/Makefile.am, supplements/sparc/bsp.t, supplements/sparc/callconv.t, supplements/sparc/cpumodel.t, supplements/sparc/cputable.t, supplements/sparc/fatalerr.t, supplements/sparc/intr_NOTIMES.t, supplements/sparc/memmodel.t, supplements/sparc/preface.texi, supplements/sparc/sparc.texi, supplements/sparc/timeERC32.t, supplements/template/.cvsignore, supplements/template/BSP_TIMES, supplements/template/ChangeLog, supplements/template/Makefile.am, supplements/template/bsp.t, supplements/template/callconv.t, supplements/template/cpumodel.t, supplements/template/cputable.t, supplements/template/fatalerr.t, supplements/template/intr_NOTIMES.t, supplements/template/memmodel.t, supplements/template/preface.texi, supplements/template/template.texi, supplements/template/timeBSP.t: Removed. | |||||
2003-09-19 | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -12/+5 | |
* cpright.texi, setup.texi: Merge from branch. * rtems.texi.in: New file. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -3/+5 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
2000-04-26 | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-02-09 | Changed date. | Joel Sherrill | 1 | -1/+1 | |
1998-08-13 | Changed phone number to reflect new area code. | Joel Sherrill | 1 | -2/+2 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -2/+2 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-06-04 | changed edition and version information | Joel Sherrill | 1 | -0/+1 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+42 | |
