path: root/doc/bsp_howto (unfollow)
2000-08-25Adding ChangeLogs.Joel Sherrill1-0/+3
2000-06-14Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill1-1/+0
<corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
2000-06-10Purged as many egcs references as possible.Joel Sherrill1-3/+3
2000-06-10Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-4/+7
which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
2000-06-01Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill5-71/+71
Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
2000-05-01File rendered obsolete by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill1-342/+0
2000-05-01Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2-37/+31
It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
2000-04-27New files. First attempt.Joel Sherrill1-0/+37
2000-04-26Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-152/+460
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
1999-11-16Changed copyright date to 1999.Joel Sherrill17-17/+17
1999-10-25Enabled Ada95 interrupt support chapter and reformatted aJoel Sherrill6-35/+48
bunch of stuff to avoid line wrappings.
1999-10-11Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1-5/+4
1999-10-07Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1-1/+1
pdf version of figures.
1999-10-01Numerous minor changes required to transition to the latest versionJoel Sherrill3-9/+9
of texinfo and TeX. This version of the tools can produce PDF with figures included.
1999-10-01Added return 0 to pollWrite and InterruptWrite examples. ChrisJoel Sherrill1-7/+4
Johns <ccj@acm.org> suggested this.
1999-07-03Removed concept of distribution level.Joel Sherrill1-1/+0
1999-04-20Updated to reflect inclusion of IRQ test in ada examples.Joel Sherrill1-3/+7
1999-04-19New file based on notes from Jiri Gaisler <jgais@ws.estec.esa.nl>.Joel Sherrill1-0/+77
1999-03-02This file is linked inJoel Sherrill1-284/+0
1999-02-10Corrected titleJoel Sherrill1-1/+1
1999-02-09Install the PostScript file.Joel Sherrill1-1/+1
1998-12-17Incorporated Jeff's suggestions.Joel Sherrill11-33/+78
1998-11-19Changed version string.Joel Sherrill1-0/+284
Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk.
1998-11-19Applied updates from remote work while doing class.Joel Sherrill13-312/+1828
1998-10-21Corrections from Jennifer and Jeff plus additions to the initializationJoel Sherrill5-87/+285
chapter.
1998-10-20Spell checked.Joel Sherrill3-3/+3
1998-10-20Added much text to the linkcmds chapter.Joel Sherrill3-44/+68
Cleaned up sections in the target dependent info file.
1998-10-20Links between chapters up to Linker Script in place.Joel Sherrill3-45/+119
First draft of chapters up to and include Makefiles written.
1998-10-20Significant additions.Joel Sherrill1-45/+156
1998-10-20Renamed the target dependent code chapter.Joel Sherrill1-2/+2
1998-10-20Added some links between chapters.Joel Sherrill1-9/+8
1998-10-20Spacing changed.Joel Sherrill1-3/+2
1998-10-20Added new chapters.Joel Sherrill1-15/+55
1998-10-20Added multiple chapters and reordered them somewhat.Joel Sherrill1-2/+16
1998-10-20New files.Joel Sherrill7-0/+84
1998-10-20Added numerous comments to the linker script.Joel Sherrill1-243/+271
Now this chapter has no two column stuff in it.
1998-10-15Changed reference to KA9Q driver.Joel Sherrill1-51/+27
Cleaned up description of the make/custom file.
1998-10-15Cleaned up where Geoffroy had this in 2-column format.Joel Sherrill1-14/+33
1998-10-15Added more to the list of chapters.Joel Sherrill1-9/+30
1998-10-15Redid sections to have right depth.Joel Sherrill3-41/+40
1998-10-15Removed bsp structure as chapter and renamed some other chapters.Joel Sherrill1-4/+2
1998-10-15Removed bspstruct.t.Joel Sherrill1-11/+7
Commented lines which installed files.
1998-10-15Cleaned up bad line wrap which was only a long sequence of ???Joel Sherrill1-1/+1
1998-10-15Merged bsp structure into target dependent files chapter.Joel Sherrill2-48/+64
1998-10-12Changed section numbers.Joel Sherrill11-93/+86
1998-08-28Added author credit.Joel Sherrill1-0/+5
1998-08-28Added CVS Ids.Joel Sherrill9-0/+72
1998-08-28Added top level file and cleaned up chapter namesJoel Sherrill7-6/+127
1998-08-28Undid renaming.Joel Sherrill1-0/+0
1998-08-28Renamed intro to preface.Joel Sherrill1-0/+0
