* | Spacing changed. | Joel Sherrill | 1998-10-20 | 1 | -3/+2 | |
* | Added new chapters. | Joel Sherrill | 1998-10-20 | 1 | -15/+55 | |
* | Added multiple chapters and reordered them somewhat. | Joel Sherrill | 1998-10-20 | 1 | -2/+16 | |
* | New files. | Joel Sherrill | 1998-10-20 | 7 | -0/+84 | |
* | Added numerous comments to the linker script. | Joel Sherrill | 1998-10-20 | 1 | -243/+271 | |
| | | | | Now this chapter has no two column stuff in it. | |||||
* | Changed reference to KA9Q driver. | Joel Sherrill | 1998-10-15 | 1 | -51/+27 | |
| | | | | Cleaned up description of the make/custom file. | |||||
* | Cleaned up where Geoffroy had this in 2-column format. | Joel Sherrill | 1998-10-15 | 1 | -14/+33 | |
* | Added more to the list of chapters. | Joel Sherrill | 1998-10-15 | 1 | -9/+30 | |
* | Redid sections to have right depth. | Joel Sherrill | 1998-10-15 | 3 | -41/+40 | |
* | Removed bsp structure as chapter and renamed some other chapters. | Joel Sherrill | 1998-10-15 | 1 | -4/+2 | |
* | Removed bspstruct.t. | Joel Sherrill | 1998-10-15 | 1 | -11/+7 | |
| | | | | Commented lines which installed files. | |||||
* | Cleaned up bad line wrap which was only a long sequence of ??? | Joel Sherrill | 1998-10-15 | 1 | -1/+1 | |
* | Merged bsp structure into target dependent files chapter. | Joel Sherrill | 1998-10-15 | 2 | -48/+64 | |
* | Changed section numbers. | Joel Sherrill | 1998-10-12 | 11 | -93/+86 | |
* | Added author credit. | Joel Sherrill | 1998-08-28 | 1 | -0/+5 | |
* | Added CVS Ids. | Joel Sherrill | 1998-08-28 | 9 | -0/+72 | |
* | Added top level file and cleaned up chapter names | Joel Sherrill | 1998-08-28 | 7 | -6/+127 | |
* | Undid renaming. | Joel Sherrill | 1998-08-28 | 1 | -0/+0 | |
* | Renamed intro to preface. | Joel Sherrill | 1998-08-28 | 1 | -0/+0 | |
* | Base files | Joel Sherrill | 1998-08-28 | 10 | -25/+1151 | |
* | New file | Joel Sherrill | 1998-08-28 | 1 | -0/+94 | |
