2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2008-09-30 | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* bsp_howto/timer.t: Eliminate uses of old benchmark timer names. | |||||
2008-09-08 | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -25/+10 | |
* bsp_howto/timer.t: Update documentation to reflect Timer Driver renaming. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1998-12-17 | Incorporated Jeff's suggestions. | Joel Sherrill | 1 | -1/+1 | |
1998-11-19 | Applied updates from remote work while doing class. | Joel Sherrill | 1 | -37/+84 | |
1998-10-15 | Cleaned up bad line wrap which was only a long sequence of ??? | Joel Sherrill | 1 | -1/+1 | |
1998-10-12 | Changed section numbers. | Joel Sherrill | 1 | -3/+3 | |
1998-08-28 | Added CVS Ids. | Joel Sherrill | 1 | -0/+8 | |
1998-08-28 | Base files | Joel Sherrill | 1 | -0/+66 | |
