See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html
for instructions on how to do this.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* ata.t, ide-ctrl.t: New file.
* .cvsignore: Added new .texi files.
* Makefile.am:: Added new files to generate.
* bsp_howto.texi: Added new chapters.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
