* analog.t, bsp_howto.texi, discrete.t, nvmem.t, target.t: Merge from
branch.
* bsp_howto.texi: Set @setfilename bsp_howto.info.
* ata.t, ide-ctrl.t: New file.
* .cvsignore: Added new .texi files.
* Makefile.am:: Added new files to generate.
* bsp_howto.texi: Added new chapters.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
bunch of stuff to avoid line wrappings.
figures included.
