In PDF, DVI, and PostScript files, the contents of the @top
node were being printed. These are intended only for info
and html output formats.
Texinfo 5.0 is a complete reimplementation and has stricter
interpretations of the texinfo language.
PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
* bsp_howto/.cvsignore, bsp_howto/Makefile.am,
bsp_howto/bsp_howto.texi: Add Frame Buffer Device Driver shell.
* bsp_howto/framebuffer.t: New file.
* user/conf.t: Add CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* analog.t, bsp_howto.texi, discrete.t, nvmem.t, target.t: Merge from
branch.
* bsp_howto.texi: Set @setfilename bsp_howto.info.
* ata.t, ide-ctrl.t: New file.
* .cvsignore: Added new .texi files.
* Makefile.am:: Added new files to generate.
* bsp_howto.texi: Added new chapters.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
bunch of stuff to avoid line wrappings.
figures included.
