* | 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-05 | 1 | -91/+0 |
| | | | | | | | | | * ChangeLog: Merge-in bsp_howto/ChangeLog. * ChangeLog: Merge-in porting/ChangeLog. * ChangeLog: Merge-in rgdb_specs/ChangeLog. * ChangeLog: Merge-in rtems_gdb/ChangeLog. * bsp_howto/ChangeLog, porting/ChangeLog, rgdb_specs/ChangeLog, rtems_gdb/ChangeLog: Remove. | ||||
* | Fix broken ChangeLog entry. | Ralf Corsepius | 2004-01-17 | 1 | -1/+1 |
* | 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-17 | 1 | -0/+4 |
| | | | | * Makefile.am: Add ata.t, ide_ctrl.t to EXTRA_DIST. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 1 | -0/+4 |
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -0/+5 |
| | | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 1 | -0/+4 |
| | | | | * Makefile.am: Merger from rtems-4-6-branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 1 | -0/+5 |
| | | | | | * analog.t, bsp_howto.texi, discrete.t, nvmem.t, target.t: Merge from branch. | ||||
* | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-22 | 1 | -0/+5 |
| | | | | | * adaintr.t, ata.t, target.t: Reconcile differences between CVS trunk and 4.6 branch. | ||||
* | 2003-08-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-13 | 1 | -0/+4 |
| | | | | * ide-ctrl.t: Merger from 4.6-branch. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 1 | -0/+5 |
| | | | | | * makefiles.t, support.t: Updated to reflect use of automake in addition to autoconf. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 1 | -0/+4 |
| | | | | * bsp_howto.texi: Set @setfilename bsp_howto.info. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 1 | -0/+4 |
| | | | | * Makefile.am: Put GENERATED_FILES into $builddir. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 1 | -0/+8 |
| | | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | ||||
* | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-21 | 1 | -0/+4 |
| | | | | * stamp-vti, version.texi: Regenerated. | ||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 1 | -0/+4 |
* | 2002-10-24 Eugeny S. Mints <Eugeny.Mints@oktet.ru> | Joel Sherrill | 2002-10-28 | 1 | -0/+8 |
| | | | | | | | | * ata.t, ide-ctrl.t: New file. * .cvsignore: Added new .texi files. * Makefile.am:: Added new files to generate. * bsp_howto.texi: Added new chapters. * stamp-vti, version.texi: Regenerated. | ||||
* | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-24 | 1 | -0/+4 |
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+4 |
| | | | | * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-18 | 1 | -0/+4 |
| | | | | * Makefile.am: include main.am, require automake-1.5. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -0/+4 |
| | | | | * .cvsignore: Added rtems_header.html and rtems_footer.html. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-25 | 1 | -0/+3 |
