This patch adds the initial version of the SMP chapter to the Users Guide.
Rename rtems_internal_error_description() to
rtems_internal_error_text(). Rename rtems_fatal_source_description() to
rtems_fatal_source_text(). Rename rtems_status_code_description() to
rtems_status_text(). Remove previous implementation of
In PDF, DVI, and PostScript files, the contents of the @top
node were being printed. These are intended only for info
and html output formats.
See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html
for instructions on how to do this.
Texinfo 5.0 is a complete reimplementation and has stricter
interpretations of the texinfo language.
Joel editted the documentation for clarity, grammar and technical
correctness. I also moved it in the manual and added @findex
entries. The core work was just polished.
Author: Krzysztof Mięsowicz <krzysztof.miesowicz@gmail.com>
for details.
Adds documentation on the scheduler options and scheduler selection
to the User's Manual to reflect changes made in the development of
pluggable scheduling with EDF and CBS schedulers.
* project.am (MOSTLYCLEANFILES): Remove index.html.
* ada_user/Makefile.am (CLEANFILES): Fixup image handling.
PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
* ada_user/version.texi, bsp_howto/version.texi,
cpu_supplement/version.texi, develenv/version.texi,
filesystem/version.texi, networking/version.texi,
porting/version.texi, posix1003.1/version.texi,
posix_users/version.texi, shell/version.texi, started/version.texi,
user/version.texi: Update to match when files in directory where last
touched.
* ada_user/.cvsignore: Add missing files.
* ada_user/Makefile.am: Add ObjectId pdf files.
* ada_user/Makefile.am, ada_user/ada_user.texi, user/Makefile.am,
user/c_user.texi, user/concepts.t, user/overview.t,
user/preface.texi, user/schedule.t, user/sem.t: Add table of figures.
Add text and graphic of tree illustrating valid combinations of
semaphore attributes.
* user/semaphore_attributes.eps, user/semaphore_attributes.png:
New files.
* ada_user/Makefile.am: Fix typo.
* ada_user/Makefile.am, user/Makefile.am, user/concepts.t: Add 16 bit
object Id format information.
* user/ObjectId-16Bits.eps, user/ObjectId-16Bits.png: New files.
* ada_user/Makefile.am: Make Ada manual build again after adding
figure.
* doc/user/chains.t: New.
* doc/ada_user/ada_user.texi, doc/user/Makefile.am,
doc/user/c_user.texi, doc/user/dirstat.texi: Updated for the
chains documentation.
* ada_user/Makefile.am, ada_user/ada_user.texi: Now builds.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* ada_user/Makefile.am, ada_user/ada_user.texi: Ada API manual now
builds again.
* ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore,
develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore,
networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore,
posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi,
cpu_supplement/sparc.t: Add Blackfin CPU supplement chapter and get
everything building from previous breakages.
* cpu_supplement/bfin.t: New file.
* ChangeLog: Merge-in ada_user/ChangeLog.
* ChangeLog: Merge-in started_ada/ChangeLog.
* ada_user/ChangeLog, started_ada/ChangeLog: Remove.
* Makefile.am: Cosmetics.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, ada_user/ada_user.texi: Merge from branch.
* acinclude.m4, images/rtems_logo.jpg: New files.
* SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
* ada_user.texi: Set @setfilename ada_user.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
