path: root/doc/ada_user (follow)
* Changed settings for RPREFIX and DIRPREFIX.Joel Sherrill1998-08-131-2/+2
* Corrected wildcard for info filesJoel Sherrill1998-04-021-1/+2
* Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1998-03-301-16/+7
* Corrected distribution levels for htmlJoel Sherrill1998-03-301-1/+1
* Added distribution level to each manualJoel Sherrill1998-03-301-2/+3
* Added directive and constant prefixes.Joel Sherrill1998-03-271-0/+2
* Added variables for dates and revision infoJoel Sherrill1998-03-261-4/+4
* Updated copyrightsJoel Sherrill1998-02-063-3/+3
* minor updates .. mostly versionJoel Sherrill1998-01-231-4/+5
* corrected typos and changes LANGUAGE to RTEMS-LANGUAGE.Joel Sherrill1997-07-311-1/+1
* added CVS Id stringJoel Sherrill1997-06-043-0/+6
* changed edition and version informationJoel Sherrill1997-06-041-2/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-5/+6
| | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives.
* new file -- Ada specificJoel Sherrill1997-05-303-3/+22
* first cut at adding an Ada bindings manualJoel Sherrill1997-05-292-0/+227
