path: root/doc/ada_user (unfollow)
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+4
* Makefile.am: Cosmetics.
2003-12-112003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-15/+19
2003-11-262003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-0/+7
* Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos.
2003-09-222003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-2/+6
2003-09-192003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+1
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, rtems_support.html.in, ada_user/ada_user.texi: Merge from branch. * acinclude.m4, images/rtems_logo.jpg: New files. * SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
2003-01-252003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+5
* ada_user.texi: Set @setfilename ada_user.info.
2003-01-242003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-13/+17
2003-01-222003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-13/+15
* version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort.
2003-01-212003-01-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-4/+8
2002-11-132002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-4/+8
2002-10-242002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-4/+8
2002-07-302002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-4/+4
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+4
2002-01-20regeneratedJoel Sherrill2-2/+4
2002-01-20regeneratedJoel Sherrill2-2/+2
2002-01-182002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+6
2002-01-172001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+6
2002-01-172001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-7/+8
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation.
2000-09-222000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
2000-08-25Adding ChangeLogs.Joel Sherrill1-0/+3
2000-06-14Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill1-1/+0
<corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
2000-06-10Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-30/+29
which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
2000-06-01Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill5-33/+37
Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
2000-05-08Added Data Types chapter.Joel Sherrill2-2/+4
2000-05-01Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-22/+12
It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
2000-04-27New files. First attempt.Joel Sherrill1-0/+33
2000-04-26Patches rtemsdoc-4.5.0-rc.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
that addresses the following: The patch below should * fix the *pdf cleanup handling * fix dependencies between pdf-documents and texi-files It also contains an attempt to let networking/schedule.t use states.pdf instead of ascii graphics, but though each pdf image looks nice, it comes out weirdly distorted in the main pdf document.
2000-04-26Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-73/+52
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
1999-11-16Changed copyright date to 1999.Joel Sherrill3-3/+3
1999-10-11Added files generated by index process to clean stanza.Joel Sherrill1-0/+1
1999-10-11Enabled index generation.Joel Sherrill1-4/+4
1999-10-11Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1-3/+4
1999-10-07Copy figures from user guide directory so they can be included in theJoel Sherrill1-7/+15
generated document. User $(PROJECT) instead of ada_user
1999-10-01Numerous minor changes required to transition to the latest versionJoel Sherrill2-3/+8
of texinfo and TeX. This version of the tools can produce PDF with figures included.
1999-07-03Removed concept of distribution level.Joel Sherrill1-1/+0
1998-08-13Changed settings for RPREFIX and DIRPREFIX.Joel Sherrill1-2/+2
1998-04-02Corrected wildcard for info filesJoel Sherrill1-1/+2
1998-03-30Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1-16/+7
1998-03-30Corrected distribution levels for htmlJoel Sherrill1-1/+1
1998-03-30Added distribution level to each manualJoel Sherrill1-2/+3
1998-03-27Added directive and constant prefixes.Joel Sherrill1-0/+2
1998-03-26Added variables for dates and revision infoJoel Sherrill1-4/+4
1998-02-06Updated copyrightsJoel Sherrill3-3/+3
1998-01-23minor updates .. mostly versionJoel Sherrill1-4/+5
1997-07-31corrected typos and changes LANGUAGE to RTEMS-LANGUAGE.Joel Sherrill1-1/+1
1997-06-04added CVS Id stringJoel Sherrill3-0/+6
1997-06-04changed edition and version informationJoel Sherrill1-2/+2
1997-05-31Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1-5/+6
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives.
1997-05-30new file -- Ada specificJoel Sherrill3-3/+22
1997-05-29first cut at adding an Ada bindings manualJoel Sherrill2-0/+227
