* doc/user/chains.t: New.
* doc/ada_user/ada_user.texi, doc/user/Makefile.am,
doc/user/c_user.texi, doc/user/dirstat.texi: Updated for the
chains documentation.
* ada_user/Makefile.am, ada_user/ada_user.texi: Now builds.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* ada_user/Makefile.am, ada_user/ada_user.texi: Ada API manual now
builds again.
* ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore,
develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore,
networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore,
posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* ada_user/Makefile.am, ada_user/ada_user.texi,
cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi,
cpu_supplement/sparc.t: Add Blackfin CPU supplement chapter and get
everything building from previous breakages.
* cpu_supplement/bfin.t: New file.
* ChangeLog: Merge-in ada_user/ChangeLog.
* ChangeLog: Merge-in started_ada/ChangeLog.
* ada_user/ChangeLog, started_ada/ChangeLog: Remove.
* Makefile.am: Cosmetics.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, ada_user/ada_user.texi: Merge from branch.
* acinclude.m4, images/rtems_logo.jpg: New files.
* SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
* ada_user.texi: Set @setfilename ada_user.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
generated document.
User $(PROJECT) instead of ada_user
figures included.
