path: root/doc/ada_user/ada_user.texi (follow)
* Changed settings for RPREFIX and DIRPREFIX.Joel Sherrill1998-08-131-2/+2
* Added directive and constant prefixes.Joel Sherrill1998-03-271-0/+2
* Added variables for dates and revision infoJoel Sherrill1998-03-261-4/+4
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* minor updates .. mostly versionJoel Sherrill1998-01-231-4/+5
* corrected typos and changes LANGUAGE to RTEMS-LANGUAGE.Joel Sherrill1997-07-311-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* changed edition and version informationJoel Sherrill1997-06-041-2/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-5/+6
| | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives.
* new file -- Ada specificJoel Sherrill1997-05-301-1/+1
* first cut at adding an Ada bindings manualJoel Sherrill1997-05-291-0/+163
