2004-02-05 | 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -60/+0 | |
* ChangeLog: Merge-in ada_user/ChangeLog. * ChangeLog: Merge-in started_ada/ChangeLog. * ada_user/ChangeLog, started_ada/ChangeLog: Remove. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Cosmetics. | |||||
2003-12-11 | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
2003-11-26 | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos. | |||||
2003-09-22 | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Merger from rtems-4-6-branch. | |||||
2003-01-25 | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* ada_user.texi: Set @setfilename ada_user.info. | |||||
2003-01-24 | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Put GENERATED_FILES into $builddir. | |||||
2003-01-22 | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+8 | |
* version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | |||||
2003-01-21 | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* stamp-vti, version.texi: Regenerated. | |||||
2002-11-13 | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
2002-10-24 | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2002-01-18 | 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: include main.am, require automake-1.5. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* .cvsignore: Added rtems_header.html and rtems_footer.html. | |||||
2000-08-25 | Adding ChangeLogs. | Joel Sherrill | 1 | -0/+0 | |
2000-08-10 | Adding ChangeLogs. | Joel Sherrill | 1 | -0/+3 | |
