path: root/doc/VERSION (unfollow)
2002-04-112002-04-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+0
* VERSION, bootstrap: Removed as unneeded.
2002-04-082002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-7/+0
* bootstrap: Remove. * VERSION: Remove. * Makefile.am: Remove bootstrap. Add ACLOCAL_AMFLAGS. * configure.ac: Add RTEMS_TOP.
2002-01-172002-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* VERSION: Updated to rtems-doc-ss-20010117.
2002-01-172002-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+3
* VERSION: Updated to rtems-doc-eng-20010816b-d1.
2002-01-172001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation.
2001-10-302001-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+5
* VERSION: New file.
2000-04-26Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-5/+0
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
1999-11-17changed version to 19991117Joel Sherrill1-1/+1
1999-10-11Changed version information.Joel Sherrill1-1/+1
1999-08-20Updated version numbers.Joel Sherrill1-1/+1
1999-07-09changed version to 19990709Joel Sherrill1-1/+1
1999-04-06changed version to 19990406Joel Sherrill1-0/+5
1999-04-06oNew file.Joel Sherrill1-0/+0
