2012-05-11 | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 1 | -4/+0 | |
These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | |||||
2000-05-08 | Updated. | Joel Sherrill | 1 | -2/+4 | |
2000-05-08 | Updated. | Joel Sherrill | 1 | -17/+4 | |
2000-05-04 | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 1 | -0/+16 | |
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
2000-04-27 | Updated. | Joel Sherrill | 1 | -0/+13 | |
1998-10-19 | Removed KA9Q issues. | Joel Sherrill | 1 | -60/+0 | |
1998-05-15 | New file. | Joel Sherrill | 1 | -0/+137 | |
