path: root/doc/Makefile (unfollow)
2000-04-26Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-57/+0
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
1999-10-13Updated copyright date.Joel Sherrill1-0/+1
1999-10-11Install all of the gif's in the common directory.Joel Sherrill1-0/+1
1999-10-07Enabled building pdf.Joel Sherrill1-1/+1
1999-10-06Disabled building PDF by default.Joel Sherrill1-1/+1
1999-10-01Numerous minor changes required to transition to the latest versionJoel Sherrill1-1/+7
of texinfo and TeX. This version of the tools can produce PDF with figures included.
1998-10-12Changed commands for installing numerous files to include $(SRCDIR).Joel Sherrill1-4/+4
1998-08-20rtems_support.html added.Joel Sherrill1-0/+2
1998-04-14added browseable RTEMSJoel Sherrill1-0/+2
1998-04-03Cleaned up installation of pictures and common html files.Joel Sherrill1-1/+0
1998-04-02Added copy of HELP.html.Joel Sherrill1-1/+1
1998-03-30Taking care of minor build problemsJoel Sherrill1-0/+1
1998-03-30Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1-8/+1
1998-03-30Added directoriesJoel Sherrill1-0/+3
1998-03-26Added build of tools to build procedure.Joel Sherrill1-5/+21
Automatically insert version information into headers and footers..
1997-07-31Corrected problem where directories where not being properly created.Joel Sherrill1-3/+3
Change path to indicate expected snapshot date.
1997-06-04Added CVS Id stringJoel Sherrill1-0/+3
1997-05-28updated to add ka9q documentsJoel Sherrill1-3/+9
1997-05-27Initial revisionJoel Sherrill1-0/+24
