* | Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 2000-05-01 | 1 | -19/+19 |
| | | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to. | ||||
* | New files. First attempt. | Joel Sherrill | 2000-04-27 | 1 | -0/+27 |
* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 2 | -117/+81 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | ||||
* | Added new URL. | Joel Sherrill | 2000-01-03 | 1 | -0/+3 |
* | Added information on RTEMS Time/Date Representatin. | Joel Sherrill | 1999-11-24 | 3 | -2/+120 |
* | Added projects chapter to FAQ. | Joel Sherrill | 1999-11-23 | 3 | -2/+122 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 10 | -10/+10 |
* | Modified url references to be dynamic links. | Charles Phillips | 1999-10-25 | 1 | -1/+1 |
* | Added definition of DDD. Modified url references to be | Charles Phillips | 1999-10-25 | 1 | -3/+3 |
| | | | | dynamic links. | ||||
* | Made html links browsable. | Charles Phillips | 1999-10-25 | 1 | -4/+3 |
* | Made urls browsable links. | Charles Phillips | 1999-10-25 | 1 | -3/+3 |
* | Made html urls browsable links. | Charles Phillips | 1999-10-25 | 1 | -1/+1 |
* | Made html urls browable links. Updated the reference to the | Charles Phillips | 1999-10-25 | 1 | -6/+48 |
| | | | | | U.S. Army Missile Command to show the merger with the Aviation Command | ||||
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -5/+4 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 4 | -23/+14 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Added BSP chapter to FAQ. | Joel Sherrill | 1999-09-02 | 3 | -1/+43 |
* | Now formats. | Joel Sherrill | 1999-08-20 | 1 | -1/+1 |
* | Fixed Gunter Magin's email address in 3 places. | Joel Sherrill | 1999-08-19 | 1 | -3/+3 |
* | Added comment explaining what this file is. | Joel Sherrill | 1999-08-19 | 1 | -0/+6 |
* | Crossgcc FAQ entry | Joel Sherrill | 1999-08-19 | 1 | -0/+52 |
* | More corrections form Gunter Magin. | Joel Sherrill | 1999-08-19 | 1 | -3/+5 |
* | Added Eric Norum's ftp site for BDM m68k. | Joel Sherrill | 1999-08-19 | 1 | -1/+9 |
* | Changed Chris Johns' email address | Joel Sherrill | 1999-08-19 | 1 | -1/+1 |
* | Added info in NT MPC8xx BDM | Joel Sherrill | 1999-08-19 | 1 | -0/+6 |
* | Added some more. | Joel Sherrill | 1999-08-18 | 2 | -12/+22 |
* | New file. | Joel Sherrill | 1999-08-18 | 1 | -0/+15 |
* | Added section on malloc reentrancy. | Joel Sherrill | 1999-08-18 | 1 | -0/+22 |
* | Updated DDD section after comments from Jiri. | Joel Sherrill | 1999-08-02 | 1 | -31/+33 |
* | Added section on ddd. | Joel Sherrill | 1999-07-29 | 1 | -1/+85 |
* | Added some more information on BDM debuggers. | Joel Sherrill | 1999-07-29 | 1 | -0/+8 |
* | Added information on David Fiddes site. | Joel Sherrill | 1999-07-29 | 1 | -1/+4 |
* | Added information on using objcopy to produce IEEE-695 format. | Joel Sherrill | 1999-07-28 | 1 | -0/+29 |
* | Added shell of information on resources for embedded information. | Joel Sherrill | 1999-07-15 | 3 | -1/+44 |
* | Corrections from Chris Johns <ccj@acm.org>. | Joel Sherrill | 1999-07-15 | 1 | -4/+4 |
* | Added information on hardware to aid in debugging. Primarily this is | Joel Sherrill | 1999-07-15 | 5 | -4/+95 |
| | | | | information on gdb and bdm for the MPC8xx, MC683xx, and ColdFire. | ||||
* | New file. | Joel Sherrill | 1999-07-14 | 1 | -0/+19 |
* | Added section on Free Software that Supports RTEMS. | Joel Sherrill | 1999-07-13 | 3 | -1/+79 |
* | Added information on the workspace versus heap. | Joel Sherrill | 1999-07-09 | 1 | -0/+5 |
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Fixed typo. | Joel Sherrill | 1999-05-14 | 1 | -1/+1 |
* | Added tool hints. | Joel Sherrill | 1999-05-14 | 3 | -1/+12 |
* | New file. | Joel Sherrill | 1999-05-14 | 1 | -0/+47 |
* | Added debugging hints to the FAQ. | Joel Sherrill | 1999-04-19 | 3 | -8/+10 |
* | New file. | Joel Sherrill | 1999-04-19 | 1 | -0/+43 |
* | Updated to include first set of questions. | Joel Sherrill | 1999-04-19 | 2 | -1/+124 |
* | First attempt to build. | Joel Sherrill | 1999-04-19 | 3 | -5/+20 |
* | New file. | Joel Sherrill | 1999-04-19 | 2 | -0/+176 |
