* Makefile.am: Cosmetics.
* basic.t, entry: Obsoleting HP PA-RISC port and removing all
references.
* FAQ.texi, basic.t, build45.t, entry, tools.t: Merge from branch.
* build45.t: Fix typo (config.long).
* basic.t, entry: Remove A29k references and update.
* FAQ.texi: Set @setfilename FAQ.info.
* build45.t: Fix typo in previous patch.
* build45.t: Several fixes and additions.
* FAQ.texi: Rename section "Building RTEMS 4.5" into "Building
RTEMS".
build45.t: Remove references to 4.5. Several minor updates.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
how to get it from a file other thatn the executable.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
<corsepiu@faw.uni-ulm.de> to correct some typos and improve the
information for DDD and the Hitachi SH.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
dynamic links.
U.S. Army Missile Command to show the merger with the Aviation
Command
