2000-04-26 | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -117/+0 | |
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | |||||
1999-11-24 | Added information on RTEMS Time/Date Representatin. | Joel Sherrill | 1 | -2/+7 | |
1999-11-23 | Added projects chapter to FAQ. | Joel Sherrill | 1 | -2/+7 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1 | -5/+4 | |
1999-10-07 | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1 | -1/+1 | |
pdf version of figures. | |||||
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -2/+7 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1999-09-02 | Added BSP chapter to FAQ. | Joel Sherrill | 1 | -1/+6 | |
1999-07-15 | Added shell of information on resources for embedded information. | Joel Sherrill | 1 | -1/+7 | |
1999-07-15 | Added information on hardware to aid in debugging. Primarily this is | Joel Sherrill | 1 | -1/+12 | |
information on gdb and bdm for the MPC8xx, MC683xx, and ColdFire. | |||||
1999-07-13 | Added section on Free Software that Supports RTEMS. | Joel Sherrill | 1 | -1/+7 | |
1999-07-03 | Removed concept of distribution level. | Joel Sherrill | 1 | -1/+0 | |
1999-05-14 | Added tool hints. | Joel Sherrill | 1 | -1/+6 | |
1999-04-19 | Added debugging hints to the FAQ. | Joel Sherrill | 1 | -5/+5 | |
1999-04-19 | Updated to include first set of questions. | Joel Sherrill | 1 | -1/+1 | |
1999-04-19 | First attempt to build. | Joel Sherrill | 1 | -3/+3 | |
1999-04-19 | New file. | Joel Sherrill | 1 | -29/+9 | |
1999-02-10 | Now generates HTML, PostScript, and info correctly. | Joel Sherrill | 1 | -12/+11 | |
1999-02-10 | Base version. | Joel Sherrill | 1 | -36/+40 | |
1998-10-27 | Corrected 2nd invocation of texi2dvi so indices are built. | Joel Sherrill | 1 | -1/+0 | |
1998-10-20 | Added sections and had to change build menu commands. | Joel Sherrill | 1 | -1/+1 | |
1998-04-13 | Updated to include Steve's figures for the first time. | Joel Sherrill | 1 | -1/+3 | |
1998-04-13 | Added Resources on the Internet section | Joel Sherrill | 1 | -1/+1 | |
1998-04-11 | Now a passable Ada manual | Joel Sherrill | 1 | -5/+5 | |
1998-04-11 | Base line -- copied from C/C++ | Joel Sherrill | 1 | -4/+4 | |
1998-04-10 | Printed copy given to Steve and Mark | Joel Sherrill | 1 | -2/+2 | |
1998-04-10 | In texinfo nicely with all version dependent information | Joel Sherrill | 1 | -7/+7 | |
now in variables and some updates already in place. | |||||
1998-04-09 | Now builds clean for info, html, and ps. | Joel Sherrill | 1 | -1/+1 | |
1998-04-09 | base version | Joel Sherrill | 1 | -0/+87 | |
