* configure.ac, index.html.in: mips64orion port removed as mips port
more completely covers the MIPS family.
* rtems_support.html.in: Removed.
* project.am: Remove $(PROJECT).info* from CLEANFILES (Doesn't work
with automake-1.7f/1.8 anymore).
* Makefile.am: Add missing '\'. Reformat.
PR 513/doc
* Makefile.am, index.html.in: Rename Getting Started to be non-language
specific and remove link to Ada Getting Started. Also install missing
graphic.
* images/ChangeLog: Removed.
* ChangeLog: Merge images/ChangeLog.
* common/ChangeLog: Removed.
* ChangeLog: Merge common/ChangeLog.
* common/.cvsignore: Add rtems.texi, rtems.sed.
* configure.ac: Merger from rtems-4-6-branch.
Purge hppa1.1.
* index.html.in: Purge hppa1.1.
* project.am: Merger from rtems-4-6-branch.
* rtems_support.html.in: Purge hppa1.1.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, ada_user/ada_user.texi: Merge from branch.
* acinclude.m4, images/rtems_logo.jpg: New files.
* SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
* index.html.in: Development Environment Guide should be updated now.
* Makefile.am, configure.ac: Remove src2html references.
* index.html.in: Update to reflect partial update of Development
Environment Guide.
* index.html.in: Removed a29k reference.
* index.html.in: Fix duplicate c4x entry.
* index.html.in: Add c4x.
* configure.ac: Add c4x.
* project.am: Add version.texi hack.
* main.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF.
Append -I $(top_builddir) to TEXI2WWW_ARGS.
* project.am: Add AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF.
Override automake's .dvi.ps:-rule.
* project.am, main.am: Use automake rules to build ps, pdf, info.
Various minor changes.
* project.am: Append $($(PROJECT)_TEXINFOS) to
html-dependencies.
* configure.ac: Require autoconf-2.57.
Require automake-1.7.2.
Remove started/pictures/Makefile.
* started/Makefile.am: Merge-in pictures/Makefile.am
* started/pictures/Makefile.am: Remove.
* Makefile.am: Merge-in images/Makefile.am, common/Makefile.am.
* images/Makefile.am: Remove.
* common/Makefile.am: Remove.
* main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* index.html.in: Note that the Getting Started with GNAT/RTEMS
manual is largely obsolete now that GNAT is in GCC.
* index.html.in: Add links to multiple missing CPU supplements.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.ac: Added supplements/arm/Makefile.
* README: Updated.
* project.am: Use PATH_SEPARATOR to setup TEXINPUTS.
* VERSION, bootstrap: Removed as unneeded.
* bootstrap: Remove.
* VERSION: Remove.
* Makefile.am:
Remove bootstrap.
Add ACLOCAL_AMFLAGS.
* configure.ac: Add RTEMS_TOP.
* configure.ac: New mips supplement.
* .cvsignore: Reworked.
* Makefile.am: Remove texinfo/texinfo.tex
* bootstrap: Removed.
* configure.ac: Add pkgdocdir. Let htmldir be rooted at pkgdocdir.
* main.am: Remove TEXINFO_TEX.
* project.am: Let dvidir, psdir, pdfdir be rooted at pkgdocdir.
Remove commented out make-variables.
* .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing,
mkinstalldirs, texinfo.tex.
* Makefile.am: Add main.am to AUTOMAKE_FILES.
* configure.ac: Add AC_CONFIG_AUX_DIR([.]).
* project.am: Remove custom .texi and stamp-vti rules.
* main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* project.am: Reworked.
* main.am: New.
* configure.ac: New.
* configure.in: Removed.
* bootstrap: Sync with RTEMS's toplevel bootstrap.sh.
* VERSION: Updated to rtems-doc-ss-20010117.
* VERSION: Updated to rtems-doc-eng-20010816b-d1.
* configure.in: Changed the version to eng-20010816b.
* VERSION: New file.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
